Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
  • FZG
    • Sep 2022
    • 111
    Hello there, helpful forum people!
    I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
    On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
    The original part is not available for sale anywhere and I struggle to find a suitable equivalent part. I´m sure someone here has the knowledge to show me what my options are at this point.
    I added pictures of the part, the schematic and the boardview. Hope this helps.
    Thanks in advance!
  • FZG
    • Sep 2022
    • 111
    Re: Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
    Nobody? How far could I be off-value with a replacement part? 525uH seems to be a very unusual value. 470uH and 560uH are more common but I don´t know whether they´ll do the job or not. And what type of coil would be best to use?
    • FZG
      • Sep 2022
      • 111
      Okay, nevermind. I figured it out myself. I used a Bourns 5256-RC to replace the failed coil and now the monitor is working again, even though the replacement part is ever so slightly out of spec.
        by momaka
        03-15-2023, 10:17 PM
      • lti
        Sony MDR-IF245R transmitter LED replacement
        by lti
        I'm looking at the transmitter from these wireless headphones because the range is too short. One of the LEDs failed many years ago (nine years ago - I found pictures that I took then) and was simply bypassed to make them work again, but it seems like the range has been degrading since then. They're near-IR LEDs (I can see them dimly lit red, so they aren't the standard 940nm), and I haven't been able to find the actual wavelength. Does anyone here happen to know what replacement LEDs I should use? Maybe I can adjust the transmitter was well while I'm in there, or there's another fault. I should...
        06-28-2024, 01:47 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • Rick_1234
        LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
        by Rick_1234
        Good evening, gentlemen.
        I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
        To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
        https://drive.google.com/file/d/1L6S...ew?usp=sharing
        Things I tried
        - Bought a new AC adapter thinking that was the problem but the problem...
        06-22-2024, 04:44 PM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
