Samsung UE43RU7406 strange black figures
  • Raulnn
    • Nov 2022
    • 103
    • España
    Good afternoon! Let's see if anyone knows who can help me with this. attached photos. sometimes these strange black figures appear on the panel, in various areas. I have never seen this error. thank you
  • Raulnn
    • Nov 2022
    • 103
    • España
    Re: Samsung UE43RU7406 strange black figures
    someone?
    • Diah
      • Feb 2013
      • 6439
      Originally posted by Raulnn
      someone?
      no one can answer yours questions.. only you self... if the this black line /points move up and down when you click on screen then its dirt under the glass if not then its panel burn cells.
      • Raulnn
        • Nov 2022
        • 103
        • España
        thanks for answering. those strange figures appear and disappear, and different ones appear in another area. I think it can't be that. I forgot to put that information
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4463
          • Italy - Milan
          This is a software issue...
          • howardc64
            • Jun 2017
            • 636
            I think similar. Or maybe graphics hardware has some failure. So replacing main board is most likely.
            Damage pattern doesn't look like panel (no vertical/horizontal lines)
            • Diah
              • Feb 2013
              • 6439
              its RU series one of the shit U model cells burned on panel where this forum full of it.
              • Raulnn
                • Nov 2022
                • 103
                • España
                Thank you all for the answers. How could I rule out panel or main? I have thought about disconnecting a flat cable from the 2 that go to the panel, to see what happens. and then another. If the failure is in both cases, it could be the main board, and if it only fails in one of the 2 cases, it would be the panel. is it a good strategy? thank you
                • ducky29
                  • Dec 2015
                  • 369
                  • Europe
                  I think its a software issue. Usually emmc goes faulty. Pretty sure a new mainboard would solve this problem.
                  Usually the menus are scrambled with big and assorted letters.
                  • Diah
                    • Feb 2013
                    • 6439
                    the best way log in service menu.. if service menu displayed complete over the black spot then its software.. and you can from service menu do factory reset.
                    • Raulnn
                      • Nov 2022
                      • 103
                      • España
                      Hello! Thank you very much for answering. I also think it could be a problem with the main board. Do you know any easy test to make sure? On the other hand, he located a main board, but it is a later version of the tv model, and it has a different bn94 code. it will work?
                      • Raulnn
                        • Nov 2022
                        • 103
                        • España
                        thank you so much! Sounds like a good test to me. I never accessed the Samsung service menu, I imagine it won't be very complicated. I will investigate about it.
                        Unfortunately, on the screen of the service menu, the errors continue to appear. Is it a sign of panel failure?
                        • ducky29
                          • Dec 2015
                          • 369
                          • Europe
                          Post more pics from the menu. You should match the bn94 code. Matching BN41 code can work sometimes but its a hit or miss.
                          • Raulnn
                            • Nov 2022
                            • 103
                            • España
                            The photos
                            • Raulnn
                              • Nov 2022
                              • 103
                              • España
                              If you notice, in the service menu, the strange figures are white or yellow. they are no longer black
                              • Diah
                                • Feb 2013
                                • 6439
                                i think this TV failed QC ( quality control ) from Factory LOL
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4463
                                  • Italy - Milan
                                  ma bastaaaaaaaaa.....!
                                  maybe a failing update, have you ordered a spare main board? What do you wait?
                                  • Raulnn
                                    • Nov 2022
                                    • 103
                                    • España
                                    Mainboard or panel?
                                    • Raulnn
                                      • Nov 2022
                                      • 103
                                      • España
                                      Is there a test to determine if it's the main board before I order it? the plate with the bn94 code is very expensive and difficult to find. thank you
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4463
                                        • Italy - Milan
                                        There's no need of any test at all, this discussion about if it's the panel or the main board is by beginners, the screen doesn't interpret any thing in any way about what's inside the image, so it can't invent to misshape a character font!!! I don't believe there are so many posts in this thread, some one must review its knowledge..
                                          09-07-2024, 05:50 AM
                                        • magconpres
                                          Samsung PN50A550S1FXZA black areas are sometimes a deep red
                                          by magconpres
                                          Hi -
                                          First, thanks to everyone on this forum that provides info. I have the power cycling problem that is well covered in other threads and have been able to trouble shoot it enough using info from this forum to isolate the problem to the main board, and suspect I have the capacitor problem that has been covered so well in other posts.
                                          However, since I have the TV opened up, I thought I'd try to ix another problem I've been living with for a while.
                                          In areas of scenes that are completely black I sometimes get a deep red instead of black. It's a very...
                                          11-26-2022, 10:07 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                          09-06-2024, 11:40 PM
