Lg55uj620v no backlight
  • Edgas10
    • May 2023
    • 16
    • Portugal
    Hi there ,first post be gentle on me😁
    Have a tv to try to fix , its an lg55uj620v
    Has no backlight,image is there and sound.
    So bought a led tester and both lines measure the same
    57.4v
    There are 44 leds.
    I have all the correct voltages on the connector .
    But im only getting around 18v on the socket where the leds go on both sides.
    Measure resistance on the connector i get 32 kohms.
    I went to the icdriver i have 13 volts on vcc
    I get the 3. Something whem power on but i have no voltage geting out.(ic is a BD94121F).
    Hopping for some help thanks.
    Im not an expert ,and forgive if i have some mistakes ,im portuguese.😁
  • handsworth
    • Oct 2015
    • 174
    Re: Lg55uj620v no backlight
    1 or more bad leds. Replace all
    • Edgas10
      • May 2023
      • 16
      • Portugal
      Thanks for the aswer ,but they all lit with backligt tester
      Measure then individualy and they all light the same brightness .
      Am i missing something here?🤔
      • Edgas10
        • May 2023
        • 16
        • Portugal
        Heres some pics
        • Diah
          • Feb 2013
          • 6439
          @handsworth give you the correct answer..
          LG use LED units built in in reserve way protection zener diode. tester cant figure out if they are open or short. you need with yours DMM diode mode test each in reserve way to lit on dim and other way to read diode round 0.650
          • handsworth
            • Oct 2015
            • 174
            Had the same experience with 50UH5530. All leds light with tester but tv does not come on when powered up. Replaced all leds and tv works fine.
            • Storyteller12
              • Jun 2020
              • 625
              Plug tv in with the screen and diffuser out and power it up. you will see them light up except the one that’s bad.
              Replace all of them though as mentioned by everyone else
              • Edgas10
                • May 2023
                • 16
                • Portugal
                Originally posted by Storyteller12
                Plug tv in with the screen and diffuser out and power it up. you will see them light up except the one that's bad.
                (A side note the tv did a half second backlight flash when turned on )
                Actually i did that test ,the first rime and open the tv and i plug the tv with the diffusrr and screen not connected and they lit up.
                But im no expert and i tought they were good so closed the tv reconnected everything and tested but no backlight again.
                So i tested the strips again with the tester but i connected both positives from ech string and no more light... On one of the strings
                Opened again and one of the leds was bad.
                Ive ordered new strips,so fingers crossed
                • Edgas10
                  • May 2023
                  • 16
                  • Portugal
                  What is reserve way?
                  • Diah
                    • Feb 2013
                    • 6439
                    Reverse way.. see LED with ZD diagram used by LG LED TV
                    • Edgas10
                      • May 2023
                      • 16
                      • Portugal
                      Ah ok wlready did it i have 2.4v in foward and nothing on reverse
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        What’s the purpose of having zener diode in parallel with LED?
                        Wired this way would require each diode to have its own driver no??
                        Ahhh. Edit! Reverse polarity protection! Of course!
                        What does a zener diode do extra that a normal LED can’t though seeing as they both serve to protect from reverse polarity?
                        • Edgas10
                          • May 2023
                          • 16
                          • Portugal
                          Thanks to all ,problem solved .
                          Leds change and tv works fine.
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
                          • hollox123
                            ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                            by hollox123
                            Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                            1. Laptop keyboard doesn't work
                            2. The backlight on the laptop keyboard doesn't work
                            3. The x2 side LEDs (red) on the laptop don't work
                            The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                            I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                            But I am strongly aiming that it is somehow a BIOS-related problem,...
                            05-11-2025, 08:05 AM
                          • signal.quest
                            Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                            by signal.quest
                            I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                            03-17-2024, 10:14 AM
                          • DanPoka
                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                            by DanPoka
                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                            02-15-2025, 05:05 AM
                          • unimatrix93
                            Which resistor should I remove/replace to decrease current to backlight leds?
                            by unimatrix93
                            Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
                            However I need some help identifying the resistor I need to replace to achieve this.
                            Thank you!
                            11-29-2024, 05:05 AM
