Hisense rsag7.820.5687 no power no standby light
  • EUWest
    • May 2019
    • 44
    Hi!
    I have a power supply and on the TV no standby and no power. Have already installed a replacement power supply but the same problem.
    When I test both power supplies the main capacitors while plugged in, I get 0v.
    What could be the reason for this?
  • lotas
    • Jan 2016
    • 4538
    • Russia
    Re: Hisense rsag7.820.5687 no power no standby light
    Is it a switch? Check if the contacts are jumpered on it.
    • Diah
      • Feb 2013
      • 6355
      yes its switch
      • lotas
        • Jan 2016
        • 4538
        • Russia
        Then, when turned on, red with blue and green with yellow should be closed.
        • EUWest
          • May 2019
          • 44
          Hell no, switch was turned off while i was testing.
          Now i have standby light but it wont turn on
          • Diah
            • Feb 2013
            • 6355
            lol.. put back yours original power boards first and tell what voltage you have on the socket which it go to main boards
            • EUWest
              • May 2019
              • 44
              But back original psu and get this voltages
              19.6
              19.6
              0
              0
              12.15
              12.15
              0
              0.004
              0
              0
              Standby at 0.004 way to low. There is a buzzing sound on psu. Does this correlate with standby voltage?
              Values are same connected or not with Mainboard.
                • 12097
                • U.S.
                One easy thing to check when powerboard is noisy, is check all the solder joints and reflow any that look suspect, being careful not to bridge anything, some can really be hard to detect, a wiggle of the joint can detect a bad solder joint too, examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
                • EUWest
                  • May 2019
                  • 44
                  Thanks for this hind. Will give it a try tomorrow and Also test voltages on spare psu which i bought
                  • Diah
                    • Feb 2013
                    • 6355
                    19.6
                    19.6
                    0
                    0
                    12.15
                    12.15
                    0
                    0.004
                    0
                    0
                    please name the pins which read this value... so we do know where and what.
                    • R_J
                      • 9535
                      STB is the power supply ON/OFF signal that originates from the main board it is not a "standby" produced by the power supply. Your fault is likely the main board.
                      • EUWest
                        • May 2019
                        • 44
                        Resoldering some joints fixed it. But there is still a loud buzzing sound while tv starts.
                        And even if its turned off, there is a buzzing sound too.
                        What can it be?
                        • Diah
                          • Feb 2013
                          • 6355
                          first time i hear Hisense get cold / crack soldering joint... any way... plug the tv out from wall... and play with its Switch on / off how much you can... it could be the switch its contact not in tact so there are sparking.
                          for further show us the place you re soldered.
                          • EUWest
                            • May 2019
                            • 44
                            Uploaded and marked resoldered Pins.
                            Turning on off switch doesnt fix buzzing sound
                            • Diah
                              • Feb 2013
                              • 6355
                              you wrote you have replacement power supply, so use it and see if the buzzing remain.
                              • EUWest
                                • May 2019
                                • 44
                                Replacement psu doesnt buzz. So its specific to this psu. But however Replacement psu isnt working
                                  • 12097
                                  • U.S.
                                  Use a hairdryer to heat up those 5 electrolytic capacitors for a couple few minutes, then try it, see if there's any difference in the noise, don't wait til it cools down try it while it's still hot.
                                  • Diah
                                    • Feb 2013
                                    • 6355
                                    from yours re soldering didn't see any effect of issue TV wont tun on..
                                    you may had other issue before and it went out open.. for example the BL .. you have 2 Group you need to compare it currents if there any differences
                                      • 12097
                                      • U.S.
                                      Can easily check all the diodes and resistors on top of the board, youtube for tutorials if needed.
                                        • 12097
                                        • U.S.
                                        Also check the 3 pin components you see on heatsinks and one other, they appear to be transistors, check that none of the three pins are shorted to any of the others on the component, can look up a datasheet by putting in the info on top of component if needed. There are some 3 pin diodes that look just like transistors that will show continuity on the back 2 pins, so if ever in doubt about what you are dealing with, look up the datasheet.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • shovenose
                                          Christmas Light Power Supply Question
                                          by shovenose
                                          I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                                          Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                                          12-08-2023, 09:59 AM
