Hisense rsag7.820.5687 no power no standby light
  • EUWest
    • May 2019
    • 44
    Re: Hisense rsag7.820.5687 no power no standby light
    Tv is actual functioning. I will give it a try and Show what happens. If it fails again i will do more testing and repair attempt. So far thanks to everyone who helped me
    • nomoresonys
      • 12117
      • U.S.
      Do you mean that something you did fixed it??
        03-31-2024, 02:12 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        07-01-2024, 06:34 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
      • shovenose
        Christmas Light Power Supply Question
        by shovenose
        I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
        Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
        12-08-2023, 09:59 AM
