Re: Hisense rsag7.820.5687 no power no standby light
Do you mean that something you did fixed it??
Tv is actual functioning. I will give it a try and Show what happens. If it fails again i will do more testing and repair attempt. So far thanks to everyone who helped meLeave a comment:
Also check the 3 pin components you see on heatsinks and one other, they appear to be transistors, check that none of the three pins are shorted to any of the others on the component, can look up a datasheet by putting in the info on top of component if needed. There are some 3 pin diodes that look just like transistors that will show continuity on the back 2 pins, so if ever in doubt about what you are dealing with, look up the datasheet.Last edited by nomoresonys; 04-16-2023, 07:34 AM.Leave a comment:
Can easily check all the diodes and resistors on top of the board, youtube for tutorials if needed.Leave a comment:
from yours re soldering didn't see any effect of issue TV wont tun on..
you may had other issue before and it went out open.. for example the BL .. you have 2 Group you need to compare it currents if there any differencesLeave a comment:
Use a hairdryer to heat up those 5 electrolytic capacitors for a couple few minutes, then try it, see if there's any difference in the noise, don't wait til it cools down try it while it's still hot.Leave a comment:
Replacement psu doesnt buzz. So its specific to this psu. But however Replacement psu isnt workingLeave a comment:
first time i hear Hisense get cold / crack soldering joint... any way... plug the tv out from wall... and play with its Switch on / off how much you can... it could be the switch its contact not in tact so there are sparking.
for further show us the place you re soldered.Leave a comment:
Resoldering some joints fixed it. But there is still a loud buzzing sound while tv starts.
And even if its turned off, there is a buzzing sound too.
What can it be?Leave a comment:
STB is the power supply ON/OFF signal that originates from the main board it is not a "standby" produced by the power supply. Your fault is likely the main board.Leave a comment:
please name the pins which read this value... so we do know where and what.Leave a comment:
Thanks for this hind. Will give it a try tomorrow and Also test voltages on spare psu which i boughtLeave a comment:
One easy thing to check when powerboard is noisy, is check all the solder joints and reflow any that look suspect, being careful not to bridge anything, some can really be hard to detect, a wiggle of the joint can detect a bad solder joint too, examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5Leave a comment:
But back original psu and get this voltages
19.6
19.6
0
0
12.15
12.15
0
0.004
0
0
Standby at 0.004 way to low. There is a buzzing sound on psu. Does this correlate with standby voltage?
Values are same connected or not with Mainboard.Leave a comment:
Hell no, switch was turned off while i was testing.
Now i have standby light but it wont turn onLeave a comment:
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Assuming...7 Photos -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by shovenoseHi all,
I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...1 Photo - Loading...
