Samsung QN75Q60TAF Boot Loop fixed but no picture
  • Nicktronic
    • Mar 2023
    • 247
    Hey, I have this Samsung TV that originally had a boot loop problem. I've isolated the pins on the ribbon cable to the panel board to stop the looping. I can hear the music on startup and when I move through menus with the remote, but there is no picture. I'm wondering what pins/signals I should look for that enables the Main Board to provide the video? Is it possible the main board is damaged? Anybody have experience wtih this type of issue?
    Thanks!
  • nomoresonys
    • 12272
    • U.S.
    Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
    https://www.badcaps.net/forum/showthread.php?t=39740
    • Nicktronic
      • Mar 2023
      • 247
      As requested
      • Diah
        • Feb 2013
        • 6435
        why did you make the mask ?? if you just disconnected the LVDS complete did it still in boot loop.... also if you disconnect the cable between main boards and power boards did the LED BL light on bright ??
        • Nicktronic
          • Mar 2023
          • 247
          Yeah, I disconnected the LVDS first and the looping stopped. Haven't tried disconnecting power cable, how does that help with the video? I want to check voltages vgh and vgl, but can't identify them on the main board.
          • nomoresonys
            • 12272
            • U.S.
            Why are you fighting? do the tests as requested. Diah will not request a test that isn't needed, it's all a part of troubleshooting.
            • Nicktronic
              • Mar 2023
              • 247
              Didn't realize I was fighting, just didn't understand the relevance.
              I unplugged the cable and yes, the BL came on full brightness immediately
              • Diah
                • Feb 2013
                • 6435
                so you have short circuit on Panel. if you are lucky the short at buffer boards. it worth if you just consider working first on panel buffer boards with out LVDS in place test low R on caps / test or remove ESD diode...
                • nomoresonys
                  • 12272
                  • U.S.
                  Picture #2, need picture of the whole board, done with 2 pics. if needed.
                  • howardc64
                    • Jun 2017
                    • 636
                    Indeed, I fixed a QN50 recently similar to this. Shorted cap on buffer board. I recall googling for solution finding fairly common problem on QNs..
                    OP should followed the masked pin traces on the buffer board and likely find shorts. I used a FLIR with voltage injection and found it instantly
                    https://www.badcaps.net/forum/showpo...6&postcount=84
                    Read post #86 for debug process and solution.
                    • nomoresonys
                      • 12272
                      • U.S.
                      Indeed, I think Diah and Howardc64 are right on target.
                      • Nicktronic
                        • Mar 2023
                        • 247
                        Pins 35, 36, 37 are what's taped off fyi. I don't know if i can trace to a specific spot, i don't the close up gear to follow the traces, but i'll try.
                        • Nicktronic
                          • Mar 2023
                          • 247
                          The rest of the pics
                          • Nicktronic
                            • Mar 2023
                            • 247
                            Ok, so see the attached picture. Pin 37 doesn't matter. Pins 35 and 36 both need to be isolated to stop the loop. These pins go to the test points indicated in the picture. I'm hopeful that DT601, DT602 or IC601 is the culprit.
                            What are these chips and how should I troubleshoot further?
                            • Diah
                              • Feb 2013
                              • 6435
                              we don't have panel diagram... the ic spi. follow the pins 36 35 on MB side to see their circuit. i think they are VDD 3.3v if thus case then no bootloop but screen remain black.. so the short at other place
                              • nomoresonys
                                • 12272
                                • U.S.
                                Maybe look up the datasheet on DT601,2, unless someone remembers how to test them. The shorts can happen in the panel itself or those panel driver boards.
                                • Nicktronic
                                  • Mar 2023
                                  • 247
                                  In the pic in post #14, I see VDD3V3 above IC601. Also, see new picture for the text on top of the chips. I can't really find much except maybe BC1 is a voltage regulator? Can't find a datasheet
                                  • lotas
                                    • Jan 2016
                                    • 4745
                                    • Russia
                                    Bc1 - dt1042-04so (4 CHANNEL LOW CAPACITANCE TVS DIODE ARRAY)
                                    • howardc64
                                      • Jun 2017
                                      • 636
                                      You can trace the masked off pins in 2 directions
                                      - Towards main board to see if can find labels for what they are
                                      - I don't know if main board's t-con section will boot far enough without LVDS connected, but perhaps try that and read voltages on the masked off pins on the main board to get a clue.
                                      - Follow the test pads on the buffer board further to see what they are connected to.
                                      Can also just check all caps on buffer boards for shorts using mult-meter with beeping diode mode (+ - probe on both side of every cap). If beep continuously, then you've found the shorted rail. But still need to find the shorted component on the rail usually by various combination heat method (touch, isopropyl evaporation, FLIR, voltage injection)
                                      • Nicktronic
                                        • Mar 2023
                                        • 247
                                        See attached pic. I was trying to follow pins 35/36 on MB, but they disappear into the holes, and they aren't on the other side of the board. In my search, I found shorted caps (everything circled in orange) and a resistor? called R82 2029. Thoughts?
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
                                        • eigma
                                          Samsung UN40H5003 boot loop every ~8 seconds
                                          by eigma
                                          Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                          Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                          SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                          Main board: BN94-07592P / BN97-08922R...
                                          11-20-2024, 10:31 PM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
                                        • signedupfordownload
                                          Samsung UE49KU6500U boot loop
                                          by signedupfordownload
                                          My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                          With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                          I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                          07-29-2024, 01:56 PM
                                        • THXFX
                                          samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                          by THXFX
                                          Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                          I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                          When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                          What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                          I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                          Measured all power supply...
                                          03-20-2024, 03:21 AM
