Samsung QN75Q60TAF Boot Loop fixed but no picture
  • Nicktronic
    • Mar 2023
    • 247
    Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
    It will be tomorrow, i don't have the tools to remove an IC right now.
    • Diah
      • Feb 2013
      • 6591
      Originally posted by Nicktronic
      ok
      after this.. if there boot loop again / no start... then need to remove the ESD DT 601 & DT 602 and check again to start Tv with out mask
      • howardc64
        • Jun 2017
        • 654
        That 8 pin IC is not easy to remove. Low melt solder is probably best solution. Hot air station can do damage in that small buffer board area if not reasonably experienced.
        • nomoresonys
          • 12331
          • U.S.
          #44
          One thing is pretty simple, IF you have those caps on the mainboard reading short with everything else dis-connected from mainboard, then the short IS on the mainboard and needs to be fixed or a new mainboard.
          • lotas
            • Jan 2016
            • 4877
            • Russia
            #45
            There is a thin board, with the help of tweezers and a regular soldering iron + flux, you can easily remove it.
            • nomoresonys
              • 12331
              • U.S.
              #46
              Of course none of that will make the tv work, as long as the mainboard is shorted.
              • howardc64
                • Jun 2017
                • 654
                @howardc64, the 12 ohms was measured on the main board, i believe you mentioned R89 earlier being an inductor. It was all caps around that.
                What is the chip # to the right of the R82 inductor? N?12R 5334E? Looks like its the chip that generates the voltage that flows through the inductor and all the nearby caps connects the voltage plane to ground (also connected to the chip) for smoothing our noises. Not sure its related to the audio chip below.
                Would be good to know what the chip is and whether 12ohm between power and ground should be expected.
                • Diah
                  • Feb 2013
                  • 6591
                  where are the short on MB !!! the posts are so many and the required test not enough for me..????
                  however i just understand from OP first post he mask 35&36 and tv boot normal and can hear music and BL come on but Panel black.. and i did explain why its black because he turn off the panel by masking VDD !!!
                  so why we do need to consider back on MB if the TV booting, BL OK,and Sound OK !!!
                  • nomoresonys
                    • 12331
                    • U.S.
                    #49
                    Cuz he gots dem shorts over there on de MB, post 20.
                    • Diah
                      • Feb 2013
                      • 6591
                      OP Post #20 for me are wrong measurements
                      this why i asked him at post#33 and his answer at post #36 was the proof of his wrong measurements.
                      or did i missed some points regards my poor English LOL
                      • howardc64
                        • Jun 2017
                        • 654
                        The main board appears good given the tests performed so far (post #1 has sound+IR, only necessary to mask 2 pins on LCD panel connector) Was just curious what is the voltage rail with 12ohm caps near inductor.
                        • nomoresonys
                          • 12331
                          • U.S.
                          #52
                          Ok, how bout you test those caps properly, if your meter beeps on diode mode, put the neg probe on a ground one of the copper holes where the screws go is fine, pos. probe on each side of cap, should beep on one side not the other, or use ohm mode, should get reading on one side and very close to 0 ohms on the other.
                          • lotas
                            • Jan 2016
                            • 4877
                            • Russia
                            #53
                            There are supply lines on the motherboard, this is the power supply for the processor core and the video core, and on these lines the supply voltage is low, about 1v, but the current is a few amperes, and these lines already have a low resistance of 20, 15, 10 Om, maybe less and they cost on this line a lot of ceramic capacitors, and when measured with a multimeter, it will beep and show low resistance.
                            • nomoresonys
                              • 12331
                              • U.S.
                              #54
                              Every one that I have tested, only beeped on one side when tested from ground, unless it was bad, even with .01 resistance no beep at that resistance and beep on other side which is grounded.
                              • howardc64
                                • Jun 2017
                                • 654
                                I actually reached similar understanding on my main board. A lot of 200ohm caps on the 2x 1V rail to the SOC. All short beeped on my old Fluke 27 DMM in diode mode.
                                My background is not Electrical Engineering (can't even do ohms law well haha) but I thought the following
                                - If a logic processor has to switch at 1GHz, there can't be high resistance between the + and GND high frequency logic rails. Otherwise, need higher voltage and produce a lot more heat to switch at that speed.
                                So OP's 12ohm diode beeps are probably on SOC's core logic supply lines as you said. On my board, the 4A 1V line had a 20pin QFN voltage supply chip with markings that google can'f find a source or datasheet. Right next to a big inductor, large + and GND planes to the SOC with lots of low resistance caps. Looks like OP's circuit in this area.
                                • lotas
                                  • Jan 2016
                                  • 4877
                                  • Russia
                                  #56
                                  Yes, that's right, the lower the voltage, the greater the current and, accordingly, the lower the resistance. And can you post a photo of a DC / DC converter in a QFN package, maybe I can find what kind of chip it is.
                                  • howardc64
                                    • Jun 2017
                                    • 654
                                    Mine is just 20pin QFN with "AWRCDE" marking.
                                    More interesting to this thread is OP's DC/DC in post #20. Looks like N12R. Google also didn't find anything.
                                    But probably just for curiosity as OPs circuit seems to be working fine and mine seem stuck on dead eMMC in another thread haha.
                                    • lotas
                                      • Jan 2016
                                      • 4877
                                      • Russia
                                      #58
                                      AWRCDE - AWRxxx - SY8286A
                                      • howardc64
                                        • Jun 2017
                                        • 654
                                        Thank you! satisfies the curiosity haha. Will stop thread jacking now :P
                                        • Nicktronic
                                          • Mar 2023
                                          • 247
                                          Diah, I removed IC601 and everything else connected normally, mask removed and the boot loop is gone. The TV boots up, I hear the little samsung jingle and no picture.
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
                                          • THXFX
                                            samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                            by THXFX
                                            Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                            I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                            When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                            What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                            I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                            Measured all power supply...
                                            03-20-2024, 03:21 AM
