Samsung QN75Q60TAF Boot Loop fixed but no picture
  • Diah
    • Feb 2013
    • 6584
    Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
    his problem not about boot loop as before... tv will turn on even if he remove both DT.. the questions there will be no picture... because t-con cut it off before removing the spi or the masking he did.
    i wish i am wrong for his sake.
    • Nicktronic
      • Mar 2023
      • 247
      Originally posted by lotas
      Remove DT601 and DT602 and all of them are not needed, they cause more problems.
      After removal, check to turn on the TV without spi and 601, 602.
      Ok, I will try that
      • Nicktronic
        • Mar 2023
        • 247
        @diah, it's ok, and I thank you for all the help, do you think the panel is causing the problem and therefore the TV is garbage/recycle?
        • Diah
          • Feb 2013
          • 6584
          you placed order for new SPI and DT.. change them as they both low coast.
          who knows.. maybe there will be wounder !!!
          • Nicktronic
            • Mar 2023
            • 247
            Haha, maybe!
            • Diah
              • Feb 2013
              • 6584
              Haha, maybe!
              do it as lotas suggest to remove both DT.... maybe this is the wounder you are waiting for... you will not lost anythings.
              • Nicktronic
                • Mar 2023
                • 247
                No difference, boots up, samsung jingle, backlights on, no picture
                • lotas
                  • Jan 2016
                  • 4874
                  • Russia
                  #188
                  Now you need to solder a clean spi flash and check with it.
                  • Nicktronic
                    • Mar 2023
                    • 247
                    Once I receive it, I will. I ordered new diode packs as well.
                    • Nicktronic
                      • Mar 2023
                      • 247
                      Installed both the new SPI flash and the diode packs. Same result. I'm done with this TV, it's going to the recycling depot.
                      • nomoresonys
                        • 12330
                        • U.S.
                        #191
                        Well it was not a success BUT it's a damn interesting thread with some good info in it.
                        • Nicktronic
                          • Mar 2023
                          • 247
                          Wiring Diagram
                          Hey again, I have another Q60TAF (70" this time) and I've confirmed that if I isolate the any ONE of the following pins, the TV will stop boot looping (but still doesn't show a picture). I've found no shorted caps on the buffer boards. Pins 1, 11, 22, 28 and 82. Based on the wiring diagram of CN1300, which of these pins is critical to allowing a picture to show on screen?
                          • Nicktronic
                            • Mar 2023
                            • 247
                            Wiring diagram...
                            • Hendrink
                              • Nov 2023
                              • Japan
                              #194
                              I also have the Boot Loop issue with this exact same TV, the QN75Q60TAF. After reading through this forum and the "SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards" forum, I got the TV to turn on with image and everything, but a bunch a reddish horizontal lines display on the screen. The lines are not too noticeable, but they still affect the quality of the image.
                              I was able to fix the Boot Loop by masking pins 7-8 on the flex cable that connects to the right side buffer board, but I can't get rid of those reddish horizontal lines on the display. I have tried checking all the caps with a multimeter, I have tried injecting voltage into the board to find a short, and I have tried to follow the rails to find the issue. Unfortunately, I haven't been successful.
                              I would also like to mention that I don't have a lot of experience troubleshooting electronics, but I have a solid foundation in electrical systems. I have also tried to find the schematic for this TV, but I have been unsuccessful.
                              Any information that helps me solve this problem would be greatly appreciated.
                              • Diah
                                • Feb 2013
                                • 6584
                                did you trace the pins 7,8 where they go... to the end of buffer boards.. there may ESD diode shorted
                                also with out this U ribbon cable you will have 3/4 screen... did the line remain showing or disappear
                                • Hendrink
                                  • Nov 2023
                                  • Japan
                                  #196
                                  I was able to isolate the issue down to pin 7 specifically, and I was able to trace it down to a 56-ohms resistor at the end of the buffer board. You can see the resistor in the picture attached marked with red, and pin 7 is connected to the side pointed by the arrow. I checked ohms across the resistor and it reads good.
                                  I tried to find where the other side of the resistor led, but I wasn't successful. Also, I did as suggested and disconnected the U ribbon cable, and the lines disappeared that time.
                                  I am not sure if I should try to re-flow/replace that resistor, or go down another route. Thanks for the suggestions.
                                  • Diah
                                    • Feb 2013
                                    • 6584
                                    the other end of the R going to the gate Transistor in display which it seem shorted as know issue with this model.
                                    but i would suggest trying to remove yours mask on the U ribbon cable.. and just release one legs of this R then see if the screen come clean.
                                    • torchzack
                                      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                      by torchzack
                                      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                      08-28-2023, 07:42 AM
                                    • eigma
                                      Samsung UN40H5003 boot loop every ~8 seconds
                                      by eigma
                                      Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                      Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                      SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                      Main board: BN94-07592P / BN97-08922R...
                                      11-20-2024, 10:31 PM
                                    • arbitarytwist
                                      Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                      by arbitarytwist
                                      Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                      Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                      03-01-2025, 01:16 PM
                                    • signedupfordownload
                                      Samsung UE49KU6500U boot loop
                                      by signedupfordownload
                                      My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                      With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                      I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                      07-29-2024, 01:56 PM
                                    • THXFX
                                      samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                      by THXFX
                                      Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                      I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                      When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                      What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                      I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                      Measured all power supply...
                                      03-20-2024, 03:21 AM
