Samsung QN75Q60TAF Boot Loop fixed but no picture
  • nomoresonys
    • 12331
    • U.S.
    #61
    Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
    Leave it off and remove the other one.
    • Diah
      • Feb 2013
      • 6599
      Originally posted by Nicktronic
      Diah, I removed IC601 and everything else connected normally, mask removed and the boot loop is gone. The TV boots up, I hear the little samsung jingle and no picture.
      write the label No of this IC
      • lotas
        • Jan 2016
        • 4888
        • Russia
        #63
        Originally posted by diah
        write the label no of this ic
        gd25b32csig
        • Diah
          • Feb 2013
          • 6599
          Originally posted by lotas
          gd25b32csig
          GD25B32C I/O NOR Flash..
          he need first to check with Diode mode between pin 8 VCC and pin 4 GND
          • Nicktronic
            • Mar 2023
            • 247
            1.727 VDC - Neg lead on 4, Pos lead on 8
            0.557 VDC - Pos lead on 4, Neg lead on 8
            No beeps
            • Diah
              • Feb 2013
              • 6599
              No beeps
              its low to me..
              try to dump it hope yours programmer can read it.
              if it did... mean good sign
              • nomoresonys
                • 12331
                • U.S.
                #67
                I don't think he has a programmer.
                • Diah
                  • Feb 2013
                  • 6599
                  well if his measurements at post#65 correct... then he should put in programmer to check if it can read or not. this is the only way i do know to test NOR... if some one know other way .. welcome.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #69
                    I do not, so now what, take the other one off?
                    • Nicktronic
                      • Mar 2023
                      • 247
                      I don't have a programmer, no. My readings in Post #65 are correct.
                      @nomoresonys, are you suggesting take of DT601 and DT602?
                      • lotas
                        • Jan 2016
                        • 4888
                        • Russia
                        #71
                        What is the resistance on these pins (1,2,3,5,6,7) relative to 4 pin. (GND) without ic601?
                        • Nicktronic
                          • Mar 2023
                          • 247
                          They are all open to GND
                          • Diah
                            • Feb 2013
                            • 6599
                            don't take any parts out from the boards... buy cheap programmer and test the NOR you get it out
                            • Nicktronic
                              • Mar 2023
                              • 247
                              can you provide a link? Thanks.
                              • Diah
                                • Feb 2013
                                • 6599
                                look after CH341a the cheapest and had many helpful ways at repair
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #76
                                  Well it's one way of seeing if it is that one that is the problem but do what you want, the tv should display a picture if you have a bad one and remove it, I could be wrong, my memory isn't that great.
                                  • Diah
                                    • Feb 2013
                                    • 6599
                                    i know what you are thinking... and you may right... the t-con on the MB are toasted so no Picture or any sign... but we cant ask him right now to change MB... unless we do know the panel worth to replace MB ..
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      #78
                                      No Diah, not the mb, just maybe remove the other DT602 and see if the picture shows up, they are just like the diode packs that are going bad often, correct?
                                      • Nicktronic
                                        • Mar 2023
                                        • 247
                                        So would this include re-installing IC601 (if it's good) and then removing DT601/DT602? IC601 must be installed to provide VDD otherwise I'll never get a picture right?
                                        • Nicktronic
                                          • Mar 2023
                                          • 247
                                          I ordered it, should be here Monday or Tuesday, but I will need a little help on how to use it. Maybe a simple step by step to test my IC601?
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
                                          • THXFX
                                            samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                            by THXFX
                                            Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                            I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                            When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                            What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                            I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                            Measured all power supply...
                                            03-20-2024, 03:21 AM
