Samsung QN75Q60TAF Boot Loop fixed but no picture
  • Nicktronic
    • Mar 2023
    • 247
    Re: Samsung QN75Q60TAF Boot Loop fixed but no picture
    @Howardc64 - I tried checking all the caps on the buffer boards but no luck.
    • nomoresonys
      • 12330
      • U.S.
      Look at those caps reading short real closely with magnification maybe, see if you see anything that looks like a fine line or such, if you do then carefully remove it and recheck it and the pads where it goes on the board, see if you still have a short.
      • Nicktronic
        • Mar 2023
        • 247
        I think the caps are actually good. I tested them originally in diode mode listening for a beep. Actual resistance is about 12 ohms. Maybe that's still bad, but there is no dead short.
        • lotas
          • Jan 2016
          • 4866
          • Russia
          12 ohm is already low resistance and it's bad.
          • howardc64
            • Jun 2017
            • 654
            Here are some steps
            Confirm test point shorts
            In post #14, you traced masked off pins 35/36 to test points on the board. This is likely a shorted rail. Since you masked off these pins, no voltage is sent to these rails from main board and so TV continues to operate. But of course some power section is lost to the buffer board/panel
            Put positive multimeter tip on the test point and negative on ground (TV metal chassis that boards mounts on (usually many GND pathways from buffer boards to chassis) or some of the open copper rectangles on the buffer boards which are usually also GND and read the resistance. Maybe you will see 12ohm again like post #23.
            If short on buffer boards, which one?
            If there is a short on the buffer board, then need to determine which one. First, can you post a pic of the entire back of the TV? Looks like you have 1x main board to buffer board flex cable. I'm guessing for a 75" TV, there are 4x buffer boards and 3x dark orange colored flex that join them. Your short could be on any of the 4 buffer boards as voltage rails goes to all of them.
            To find out which buffer board has the short. First confirm the short on a particular buffer board, then remove the flex to other buffer boards/main and check the short again against the GND on the buffer board. If disappears, then short is on other boards. If remain, then its this one. Probably check all 4 buffer boards in this manner.
            Which component is shorted on the buffer board?
            This requires even more skill and experience as there are many components and usually multiple caps on every voltage rail. Pros inject voltage (need to estimate how much voltage and max current limit given the circuit) by bench power supply and use a thermal imager (and often a macro lens + video recording) to quickly which component heats up first. There are other ways... by touch, evaporating rate of isopropyl alcohol etc.
            Lets confirm you have short on the buffer boards and which one first.
            Probably can skip the main board for now, The R82 is an inductor and just a loop of wires so it will read continuous. Anyway, its next to TI TAS5749M which google says is an audio IC and your speaker connectors are just below that.
            Here is a annotated pic of your main. The red rectangle is where all the voltages for the LCD panel comes from. Rectangular chip in the middle takes 12v from PSU and generates all the voltages for the LCD (vgh ~= 20v+, vgl ~= -10v, vcom ~<= 10v) so don't go probing around the tight pitch pins around this chip. The octagons are inductors and they will probably read the voltages I gave you above (+ probe on either side of inductor, - probe on TV chassis GND). vgh/vgl/vcom are used to turn each TFT (thin film transistor) at each subpixel (R,G,B) and turn the LCD polarizer to allow the backlight through. Panel buffer boards usually also get 3.3v to run various digital logic chips.
            The solid red arrows shows traces going to the SOC under the heatsink (pixel data) and traces towards the rectangular section (where LCD power supply is)
            The dash red arrow is probably where the pin 35/36 trace points continue.. making their way towards the LCD panel power supply section.
            Anyway, probably focus on finding the short in buffer board now.
            • Nicktronic
              • Mar 2023
              • 247
              Great information, thank you @howardc64.
              When I'm doing the continuity checks from the test points to ground, do i do this with the LVDS cable disconnected?
              • lotas
                • Jan 2016
                • 4866
                • Russia
                #27
                Yes, you have to unplug the LVDS cable and unplug the U-flex between the brackets on one side.
                • Diah
                  • Feb 2013
                  • 6575
                  LVDS rail P 35 & 36 they are not the main short circuit... they are VDD. so making them mean shutdown Panel / TV booted ..., the seeking after short should be LVDS disconnected.. DMM on Diode mode black probe to buffer boards GND and the red probe move it on all caps ESD D first.
                  • Nicktronic
                    • Mar 2023
                    • 247
                    Checked every single capacitor on the buffer boards. No shorts that I can find. That means it's in the panel then, correct? Isolating the VDD (35/36) just removed the ability for the short to affect the VDD supply right? So beyond capacitors, what? Anything?
                    • howardc64
                      • Jun 2017
                      • 654
                      Maybe check if any shorts from buffer boards with all cables connected without masking off 35/36? (Don't power on TV of course)
                      Masking changes circuit connectivity. Might be best to not have it while hunting for the short.
                      • Nicktronic
                        • Mar 2023
                        • 247
                        I will check, thanks.
                        • Nicktronic
                          • Mar 2023
                          • 247
                          No difference with all cables connected
                          • Diah
                            • Feb 2013
                            • 6575
                            keep the mask on 35 & 36.. turn on and measure the V on them at MB side
                            • howardc64
                              • Jun 2017
                              • 654
                              What is the minimum connection configuration that will reproduce the 12ohm reading in post #23? Can you post a pic of this cap and any labels around it?
                              Ideally within a single buffer board but make sure reproduce it first.
                              4x buffer boards also can provide patterns for comparison. If the 12ohm short is reproducible in 1 buffer board, are there similar circuit elsewhere for comparison?
                              • howardc64
                                • Jun 2017
                                • 654
                                Yes, thats a good test. If you have a sharp probe tip + steady hands, can try the exposed contacts on the LCD cable connector. Another place might be those 2 board through holes coming off the pins. Will need to remove tiny bit of insulation to expose the copper trace. I have very sharp (like sewing needle) probe tip that can be pushed and turned a little to remove the green insulation. Anyway, can try sewing needle. Don't press too hard since they are fragile small copper traces. I guess careful scrap from Xacto knife tip will do too.
                                • Nicktronic
                                  • Mar 2023
                                  • 247
                                  @howardc64, the 12 ohms was measured on the main board, i believe you mentioned R89 earlier being an inductor. It was all caps around that.
                                  @diah, mask on, 35/36 at MB side is 3.272VDC on both pins to gnd
                                  • Diah
                                    • Feb 2013
                                    • 6575
                                    yours Photo
                                    with out masking.... you test to turn on after
                                    A- remove SPI IC 601
                                    • Nicktronic
                                      • Mar 2023
                                      • 247
                                      Sorry I don't know if i understand..... So, take the masking off, turn on tv. Measure 36 and 35 on buffer board as marked in picture?
                                      After, remove SPI IC601?....Test again?
                                      • Diah
                                        • Feb 2013
                                        • 6575
                                        no need to measure at all. just remove the spi and the mask then turn on
                                        • Nicktronic
                                          • Mar 2023
                                          • 247
                                          ok
                                          • torchzack
                                            Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                            by torchzack
                                            Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                            I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                            Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                            08-28-2023, 07:42 AM
                                          • eigma
                                            Samsung UN40H5003 boot loop every ~8 seconds
                                            by eigma
                                            Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                            Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                            SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                            Main board: BN94-07592P / BN97-08922R...
                                            11-20-2024, 10:31 PM
                                          • arbitarytwist
                                            Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                            by arbitarytwist
                                            Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                            Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                            03-01-2025, 01:16 PM
                                          • signedupfordownload
                                            Samsung UE49KU6500U boot loop
                                            by signedupfordownload
                                            My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
                                            With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
                                            I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?...
                                            07-29-2024, 01:56 PM
                                          • THXFX
                                            samsung un43nu7100 BN94-13191C/BN41-02635A boot loop problem even with tcon jumper
                                            by THXFX
                                            Hi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
                                            I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
                                            When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
                                            What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
                                            I check capacitors and diodes and didn't find any short IN MAINBOARD.
                                            Measured all power supply...
                                            03-20-2024, 03:21 AM
