This had heavy dust build up behind the long thin metal plate covering the buffer board at the bottom of the TV. Cleaning the circuit board brought the picture back.
Samsung PS-50A457P1D Sound but no picture, Fixed
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
by JohnML1975Hello All
have seen posts on this model in here but my problem sounded different so thought i would create a thread
TV will not turn on
There is no standby light
When I press ON button for remote the red standby light does flash but no picture and no sound
From the back of the TV I can see the red light on the back of the mother board
Holding torch to the screen I cannot see a picture
I removed the back cover
Observing the boards I cannot see any damage
I disconnected the main board from the power supply
the back... - Loading...
