Sharp LC-60LE550U Mainboard F905FM06 DUNTKF905WE06TV Main board keeps dying
  • m4a2t0t
    • Mar 2013
    • 276
    What would cause a main board to die when you disconnect AC power to the TV?
    This is the second board that it has happened with. All I am doing is disconnecting the power cord from the wall and plugging it back in.
    I replaced the main board because I was not getting a signal on PS_ON when pressing the power button. The PSU was/is still sending its 5v standby signal
  • lotas
    • Jan 2016
    • 4589
    • Russia
    Re: TV Main board keeps dying
    What brand, what model, what motherboard?
    • m4a2t0t
      • Mar 2013
      • 276
      Sharp LC-60LE550U
      Mainboard F905FM06 DUNTKF905WE06/
      • lotas
        • Jan 2016
        • 4589
        • Russia
        The firmware could have crashed, if Hdmi sources were connected, then the controller (processor) could have suffered.
        • m4a2t0t
          • Mar 2013
          • 276
          No source was connected.
          When I plug in power the front panel light turns on for less than a second and then turns off. Would bad firmware cause this symptom?
          • lotas
            • Jan 2016
            • 4589
            • Russia
            Yes, there may be a problem with the firmware.
            But first, check all the supply voltages on the DC / DC converters.
            • Diah
              • Feb 2013
              • 6363
              Originally posted by m4a2t0t
              No source
              hey man.. we are still being human depending on our memories not like dummy Microsoft GPT AI machine... post photos of yours main boards and all together so we can bring the memories bock to tell where and what we found on this and that. LOL
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                surge from power supply would do it
                • m4a2t0t
                  • Mar 2013
                  • 276
                  How often do you see a PWB cause a surge only when power is removed?
                  I uploaded the service manual and an image of the PWB if for whomever needed it. TCON and Main board pics and schematics are in the manual so I didnt add them. PWB wasnt in the manual.
                  • m4a2t0t
                    • Mar 2013
                    • 276
                    edit: I reconnected the supply and have all voltages now
                      • 12151
                      • U.S.
                      If you are too lazy to post pictures, then I guess I'm too lazy to help, definitely not going to dig and stumble thru a manual just to see a picture: https://www.badcaps.net/forum/showthread.php?t=39740
                        • 12151
                        • U.S.
                        That may seem a little harsh but decent pictures are what is needed and always a good starting point when troubleshooting.
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • cheeky2
                          by cheeky2
                          05-25-2024, 03:27 AM
                        • Dani_2024
                          by Dani_2024
                          10-28-2024, 05:06 PM
                        • ygorsan
                          by ygorsan
                          🧩 Problem Summary:
                          • I
                          07-28-2025, 08:34 AM
                        • Asraf Atb
                          by Asraf Atb
                          01-27-2025, 05:02 PM
