F&u fl32107 problem [tp.ms3663s.pb818]
  • g.pol
    • Dec 2012
    • 17
    • greece
    Hello
    I have the TV which is waiting for the standby light, it does not accept a command either from the remote control or from the button.
    The standby light is constantly waiting.
    I suspect it eeprom chip (25Q64CSIG)
    Where can I find the file to pass it?
  • lotas
    • Jan 2016
    • 4610
    • Russia
    Re: F&u fl32107 problem [tp.ms3663s.pb818]
    Originally posted by g.pol
    Hello
    Read the contents (Dump) of this flash and put it here, I'll take a look, if anything, I'll restore it.
    • g.pol
      • Dec 2012
      • 17
      • greece
      ok i uploaded it
      thank you
      • lotas
        • Jan 2016
        • 4610
        • Russia
        Try.
        • g.pol
          • Dec 2012
          • 17
          • greece
          Thanks for the file, which i went through but the problem remains. i used the ch341a programmer and the neoprogramer software after checking all the options in the programming button. what else could be wrong?
          • lotas
            • Jan 2016
            • 4610
            • Russia
            Try this one, if it does not help, then replace the spi flash with a new one.
            And a newer Neo program ...
            • g.pol
              • Dec 2012
              • 17
              • greece
              finally with this version the file went through and the TV worked.
              thank you very much for the valuable help.
              • jedi23
                • Oct 2022
                • 3
                I found this thread because I tried to repair a TV of a different model (MD31303). I needed to replace the TP.MS3663S.PB818 main board, but the new one had the F&u fl32107 firmware on it, so I soldered off and replaced the eeprom chip. Now the TV starts and shows the correct logo and promts that HDMI source is selected, but then the TV immediately goes back to standby (LED changes from blue to red). Theres no change to change input sources or do anything at all.
                Any idea what the problem is?
                • jedi23
                  • Oct 2022
                  • 3
                  This is the serial output from my TV. Any clues?
                  NotifyWakeupDeviceForAP(0x4)ÿUART_115200
                  BIST0-OK
                  _
                  Decomp() at 122
                  Get 1st chunk header at flash 20000
                  u32Header_BootLoaderSize=0
                  u32BOOT_LOADER_LENGTH=0
                  u32ROM_START=20080
                  u32ROM_END=261EF2
                  LOAD Frist AP: at 151
                  DebugFlag=0x0
                  u32ROM_START=0x20080
                  u32ROM_END=0x261EF2
                  u32ROM_Size=241E72
                  u32RAM_START=0xA0A00180
                  u32RAM_END=0xA0C41FF2
                  LOAD_CODE_POINT: at 182
                  DECOMPRESS_BUF=0xA2000000
                  CRC at 192
                  CRC done at 586
                  Cp AP_1 to A00180
                  [FOD]
                  No FOD data
                  Decomp at 599
                  Decomp done at 912
                  U
                  Hello Marlon:BF000000 Apr 11 2018 18:45:35
                  Apr 11 2018
                  18:45:35
                  [30m[47m
                  Hello Marlon
                  _readonly_start = 0x80A01000, _readonly_end = 0x80E19000
                  Miu protect align = 13
                  Miu protect: 0xA00000 ~ 0x1180000
                  Miu protect-align: 0xA00000 ~ 0x1180000
                  [0m
                  wPM_WakeUpDevice 0x2AB3
                  => DC_BOOT (1)
                  PM Wakeup by 0x4
                  [[utopia]] create Audio SHM data ...
                  [[utopia]] Audio TEE Info SHM is created...
                  [Audio] Get R2 BASE =
                  0
                  USB_Init_ConfigureUSB_Init_Configure done...
                  Flash is detected (0x0508, 0xC2, 0x20, 0x17)
                  MDrv_SERFLASH_Init() done
                  MApp_DB_Check()
                  MApp_DB_GEN_Init()
                  => GoodUnit=7, WriteTime=24318
                  wPM_WakeUpDevice=0x2093
                  • gsoo
                    • Oct 2013
                    • 4
                    • Ελλάδα
                    I have the same mainboard (TP.MS3663S.PB818) with BIOS-chip 25Q64 in a FL32107 TV.
                    Could someone re-share FL32107_ok.rar, please?
                    Thanks in advance!
                    • lotas
                      • Jan 2016
                      • 4610
                      • Russia
                      Thanks in advance!
                      So what's the problem? The dump is in post 6, click on it and it will download for you.
                      • gsoo
                        • Oct 2013
                        • 4
                        • Ελλάδα
                        Γεια σας,
                        samsung UE75AU9072UXXH
                        μητρική πλακέτα (BN41-02844B) με BIOS-chip FM24C256
                        Και αυτή με πρόβλημα eeprom στον ίδιο χώρο με χρόνο βλάβης 2 ημερών
                        Μπορεί κάποιος να βοηθήσει με κάποιο αρχείο παρακαλώ;
                        Ευχαριστώ εκ των προτέρων!
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • AleMonti
                          LG 55EG910V - no power and no standby light
                          by AleMonti
                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                          After checking the basics I did the following:
                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                          11-04-2024, 05:02 PM
                        • Kaar3l
                          Samsung QLED QE65Q7FNAT only standby light
                          by Kaar3l
                          TV: Samsung QLED QE65Q7FNAT
                          PSU: BN4400940A
                          MB: BN94-12832K
                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                          09-24-2024, 01:35 PM
                        • jasonbay13
                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                          by jasonbay13
                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                          12-01-2023, 09:55 PM
                        • Nicktronic
                          Samsung UN70NU6070F Standby Light flashes twice
                          by Nicktronic
                          Hey Everyone,
                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                          03-27-2023, 07:01 PM
