Sharp LC-60LE633U Inverter output voltages
  • organman
    • Mar 2023
    • 12
    Greetings, I have a Sharp LC-60LE633U when powered up only the V light comes on. I have checked the LED strips and they all light up. When the LED's are plugged into the PS board I get an output voltage of 74v DC. If I unplug the LED's the output voltage on the PS is 184v DC. Does this indicate a weak PS?
  • organman
    • Mar 2023
    • 12
    Re: Sharp LC-60LE633U Inverter output voltages
    My fellow Techs, does anyone have any information with this TV issue?
    • R_J
      • 9535
      You likely have a bad led in one of the strings in the panel, led testers are not reliable for testing a complete string, they only output around 30ma of current, and the leds can fail at higher currents supplied by the power supply, the low voltage is due to the boost circuit shutting down due to its protection circuit, the high voltage you read without the leds connected is just the caps being charged to peak voltage without any current being drawn.
      • Diah
        • Feb 2013
        • 6355
        +1
        we did covered this issue at Sharp LC 70 from user was from Singapore .. how to test PWB stand alone and BL with out dummy LED tester
        • organman
          • Mar 2023
          • 12
          Thank you for this valuable info.
          • organman
            • Mar 2023
            • 12
            I'm getting 1 long and 1 short blink code, I have checked all 4 LED strips and all LEDs are bright. My tester shows the strips will light up at 85 volts. When I perform the reset the TV will power up but there is no backlight. The LED output from the PS is 74.6 volts. Shouldn't that voltage be higher? I have looked at other threads and have not found where this problem has been addressed. Has anyone had this problem and was able to determine how to correct it? Thanks
            • organman
              • Mar 2023
              • 12
              Does anyone have the LED output voltages for this power supply board? RUNTKA848WJN1
              • CapLeaker
                Leaking Member
                • 8067
                You can put all kinds of voltage on there as much as you want, LED’s are current controlled! I point you at post #3 again. LED’s can fail in a weird way were they can measure or test “good” but under load fail miserably. If you are good you can try to override the backlights protection. But this is for testing only.
                • organman
                  Sharp LV-60LE633U inverter output voltages
                  by organman
                  03-13-2023, 06:48 PM
                • Joekhoe
                  Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                  by Joekhoe
                  Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                  I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                  The replacement as follows:
                  1. IC7905 : TNY264PN (first found exploded)
                  2. Q7915 : BT169D (exploded too)
                  3. IC7901 : 1608B (controller ic)
                  4. IC7601 :...
                  09-17-2020, 05:52 AM
                • FrancescoV
                  Onkyo HT-R390 no sound output, video output ok
                  by FrancescoV
                  Good morning everyone,
                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                  The firmware reported is the following:
                  M:1.00/11107BLP
                  D:?.??/????????
                  O:1.00/11107AL
                  The DSP firmware given the question marks seems corrupt.
                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                  05-11-2025, 02:59 AM
                • gjgib
                  Help reading schematic voltages input/output
                  by gjgib
                  Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                  I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                  I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                  I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                  05-06-2024, 08:11 PM
                • scottsman76
                  Samsung UA40D5000PR Pulsing output voltages
                  by scottsman76
                  Hi Guys
                  I Have this Samsung smart tv that needs repair.
                  with everything connected i get pulsing A5V at the PSU connector. if i unplug the main board then all voltages pulse on the output connector.
                  I dont get any voltage on the LED connector.
                  there is also an audible click around the mosfet marked below
                  The connector to the Buttons all voltages pulse (3v)
                  I have searched and found a similar problem but there was a stable 14v, but was also not repaired.
                  I checked and replaced the mosfets with no effect.
                  Any ideas where...
                  03-30-2023, 10:33 AM
