LG 47LB67 power board EAX65424001 issue
  • shybear
    • Jan 2010
    • 105
    hi,
    This TV sometimes shut off itself surely for some bad contact of power supply board that (for use and heat) wasn't planar anymore.
    Found a same on ebay at an affordable price and compared part number and component side components was exactly the same I bought it.
    The board is perfect and new and the random shut off problem disappeared but there is a dark side on the screen that isnt' present with the old board.
    Take a look on the back of the newe power board I noticed that this one hasn't some components (4 resistors and 3 transistor) that made me suppose that it was the cause that some LED of backlight didnt' work.
    I moved one by by one this componets from the old power board to the new one testing it, but the problem still exist so I suppose there is something else to add or maybe a bridge to move.
    Actually I haven't find the power board schematic but for now I start to attach missed component pictures reference.
  • shybear
    • Jan 2010
    • 105
    Re: LG 47LB67 power board EAX65424001 issue
    Originally posted by shybear
    hi,
    Solved: there is also to move R724 (47K) to R725 (se attachment), and now backlight works fine.
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • notallbad
      TCL 55RP620K power board issue
      by notallbad
      Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
      0% p_dim at 1.65v and a_dim at 1v
      50% p_dim at 3.3v and a_dim at 1.65v
      100% p_dim at 3.3v and a_dim at 2.88v
      Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
      Leds are 2 rows of 15 6v leds.
      On inspection of the power board found diode MBR3200 shorted so replaced with...
      07-12-2025, 05:45 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
      by sam_sam_sam
      After all of...
      07-13-2024, 08:14 PM
