Hi! I have this TV set that does the following:
1) I press the red power button on the remote
2) The TV turns on normally
3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
Then after it's off, it would again accept the TURN ON from the remote and same again
BUT:
-The remote does show the correct IR beam while observed thru a phone camera
-The TV works fine while using the MiRemote App in Xiaomi (power on, off, volume, channel, input, etc...)
-There is no pinhole RESET button in the back of the TV (neither sides, nowhere)
-There are no switches/pushbuttons at all under the battery cover of the remote
I want to try a full TV factory reset but I need the remote to work, and the Xiaomi MiRemote emulates all buttons correctly except the OK button, which does nothing (this happens to me on other emulated remotes) so I have no way to enter into the setup option.
Anyone can suggest anything to try?
Thanks in afvance!
BUT:
Thanks in afvance!
