HiSense 55A7500F won't obbey to remote after power on
  • edugimeno
    • May 2017
    • 572
    • Spain
    Hi! I have this TV set that does the following:
    1) I press the red power button on the remote
    2) The TV turns on normally
    3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
    4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
    Then after it's off, it would again accept the TURN ON from the remote and same again
    BUT:
    -The remote does show the correct IR beam while observed thru a phone camera
    -The TV works fine while using the MiRemote App in Xiaomi (power on, off, volume, channel, input, etc...)
    -There is no pinhole RESET button in the back of the TV (neither sides, nowhere)
    -There are no switches/pushbuttons at all under the battery cover of the remote
    I want to try a full TV factory reset but I need the remote to work, and the Xiaomi MiRemote emulates all buttons correctly except the OK button, which does nothing (this happens to me on other emulated remotes) so I have no way to enter into the setup option.
    Anyone can suggest anything to try?
    Thanks in afvance!
  • Diah
    • Feb 2013
    • 6363
    Re: HiSense 55A7500F won't obbey to remote after power on
    use yours mobile app + air mouse / usb too so you can inter service menu and choice from there reset chip
    • edugimeno
      • May 2017
      • 572
      • Spain
      Hi! Can you please explain more in detail what app you mean?
      Is this an Hisense app that lets you point at screen menus?
      • Diah
        • Feb 2013
        • 6363
        for android there are many free apps in store like Galaxy universal remote... but you wrote you are using one on xiaomi only no OK puttom.. so use it and use mouse for OK command.
        by the way yours TV okay... no fault.. the fault at Hisense RC. and this knowing issue... since TV work on other IR RC app.. mean its fine.. but the original RC weak and didn't send the code correct. take out battery press power on RC for 1 minute to discharge.... open it and clean the carbon point of it as it collect Oil / dust and the Resistances of the buttons will be change so it start send different code
        • edugimeno
          • May 2017
          • 572
          • Spain
          Ok so you mean use a normal wired USB mouse into the USB port and use it to click "OK"?
          Also about the IR, if this remote is wrong, why does it work for turning the TV on and 1 second later it does not work for turning the TV off? How does the remote know that the TV is on and stop working? This is what I don't understand.
          I did remove the batteries for a while and nothing changed
          Thanks!
          • Diah
            • Feb 2013
            • 6363
            Thanks!
            yours RC seem have eyes and ears
            Man.. disassemble yours RC and clean it all .. it will be fine.
            • edugimeno
              • May 2017
              • 572
              • Spain
              Ok I will try tomorrow both options, clean remote inside and reset TV to factory
              • Diah
                • Feb 2013
                • 6363
                well i am not sure if the original remote of A7500 build in on the top Microphone to guide the TV with voice command... if its so then you have at setting to disable or enable this function
                  • 12145
                  • U.S.
                  Does seem like your remote is dirty or shot, try a different universal remote.
                  • jsdffxf
                    • Mar 2023
                    • 9
                    • 美国
                    Is the remote control Bluetooth? The Bluetooth remote control can be used only if it is paired successfully
                    • edugimeno
                      • May 2017
                      • 572
                      • Spain
                      Ok I managed to plug a USB keyboard to it and was able to enter into the menu and select a factory reset. This changed nothing
                      Also I opened the remote and throroughfully cleaned all contacts (board side and rubber button side) and IC pins with alcohol, and I found it extremely clean before so I guess this changed nothing but I will try this later on today
                      I still resist to believe the remote is the problem. How can the remote work for turning on and then when the TV is ON it doesnt work anymore, then I turn the TV off by the panel button and the remote works again to turn on...
                      • edugimeno
                        • May 2017
                        • 572
                        • Spain
                        Nah, I checked the remote with the TV, Same thing...
                          • 12145
                          • U.S.
                          Sure, it's very possible that the only part of remote thats working is on/off.
                            • 12145
                            • U.S.
                            Grab a replacement from ebay, got one from ebay for my old dvd/vcr player a while ago, worked fine every button, think it was about 9 dollars.
                            • Diah
                              • Feb 2013
                              • 6363
                              upload here clear photo for yours RC
                              • edugimeno
                                • May 2017
                                • 572
                                • Spain
                                Not the case, check the whole post, when the TV is off the PWR button works to turn the TV ON, but when the TV is ON the PWR button doesn't work and won't turn the TV off.
                                All buttons work correctly when seen from a phone camera
                                For some reason Im afraid a replacement remote won't help. Idk...
                                • edugimeno
                                  • May 2017
                                  • 572
                                  • Spain
                                  If you mean "outside" here it is. I don't have a pic of it inside here
                                    • 12145
                                    • U.S.
                                    Did read the whole thread, just because all buttons are emitting a signal doesn't mean the signal is correct, have had more than a few remotes that emit signal but just didn't work.
                                    • edugimeno
                                      • May 2017
                                      • 572
                                      • Spain
                                      Just because all buttons are emitting a signal doesn't mean the signal is correct, have had more than a few remotes that emit signal but just didn't work.
                                      I understand, but again, why does the PWR button work when the TV is off and then does not work when the TV is on?
                                        • 12145
                                        • U.S.
                                        I had a a bad remote that worked like that not long ago, also had one that the only button that didn't work was volume down.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
