LG 43UM7100PLB - No image, just sound
  • tomalamix
    • Nov 2020
    • 32
    • Portugal
    Hy everyone,
    My living room TV is gone, no image and just sound, complete black screen.
    It is only 2months out of warranty and I've toke it to LG, it is a very recent unit and the warranty has expired just 2 months ago, diagnostic: mainboard problem and must be swapped, the price is more then the TV it self so is not worth it.
    I've explored a few 2nd hand units with the broken screen (the most common problem on LCD panels) and I've found a 49UM7100PLB, the mainboard is exactly the same. I've bought it, made the swap but nothing on the screen.
    Is there any firmware or EEPROM to be programmed before this board can be fitted in my unit? The hardware seems exactly the same, same part-number so I'm a bit confused. By the way, I checked the backlit LED's, all are good, they are all on. The P/N of the board is EAX68253604 (1.0).
    Appreciate your experienced inputs!
  • yokoono
    • Apr 2010
    • 481
    Re: LG 43UM7100PLB - No image, just sound
    Backlight ????.
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      they lied or listed the wrong board on purpose, this tv should have problems with the panel or backlight, as all other LGs in the past that are lasting 2 years then dying, I don't know how this is acceptable.
        • 12129
        • U.S.
        Check the little mlc caps on the panel driver boards for shorts or very low ohms.
        • tomalamix
          • Nov 2020
          • 32
          • Portugal
          @Biruslapio: Do you think is the panel and not the board? I guess that the panels are very reliable nowadays, but I'm not as experienced on this as you guys.
          @nomoresonys: I can check that caps, but i don't think I don't know which caps you mean exactly. I put a picture of a board here, if you can point me which to test I will use my esr02 capacitor tester to check those.
          [IMG][/IMG]
            • 12129
            • U.S.
            Was referring to the caps on the long thin panel driver boards not the mainboard.
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              all LG UJ/LJ and UH/LH series have bad panels, I am starting to see some UM appearing for sale with no image or some random lines.
              test the panel boards capacitors as nomoresonys suggested.
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • domix
                Sony KD - 65XF9005 - No image, sound OK
                by domix
                at tv KD - 65XF9005 i have a problem.
                Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                is this a common problem for this tv?
                i attached pictures of inside. Supply board looks okey, no blowed caps....
                07-21-2025, 06:37 AM
              • Kartowl
                philips 47pfl6158k/12 image faded away, sound still coming from TV
                by Kartowl
                Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                04-23-2024, 12:57 AM
              • wolf1976
                samsung ue40d6100 has no backlight no sound and image
                by wolf1976
                hi to all
                on the above model of samsung i have the faults i have told already on the title
                iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                any idea from someone what can i measure so i can find the problem ?
                the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                11-17-2024, 01:02 PM
              • howardc64
                LG 43UK6500AUA no LCD image, backlight and sound okay
                by howardc64
                Similar to another LG UK series here
                https://www.badcaps.net/forum/showthread.php?t=93943
                Have backlight and sound. no LCD image.
                • main board has integrated T-Con
                • main board T-Con has LCD DCDC/PMIC RT6950GQW QFN68 package. Richtek chip. Can't find datasheet. Chip generates VADD (10.44V), VGH (~28V), VGL (~-14.5V)
                • RT6950 pin 18-19 (clockwise) appeared to be bridged. Unlikely from my probing, looks like ball squeezage so it probably got hot
                • Cleaned up bridging. Pin 17 is VGL (-14V) Pin 20 is VGH (28V). Pin 18 (I think 19 too) jumps between VGL and VGH voltage
                03-12-2023, 01:04 PM
