Does anyone know the procedure to replace the LEDs in this Hisense 65H6570G? I see no screws to take out to get to the bezel ect.
Hisense 65H6570G
Re: Hisense 65H6570G
See if it has the little screws like there at the 1 minute mark in the video, should be little black screws on the sides if same, maybe watch a few videos of changing out the leds on these bigger sets, have to be VERY careful with the panel, they are flimsy and break very easily.Last edited by nomoresonys; 03-10-2023, 04:10 PM.Comment
Theres a little yakity yak about different methods from some members: https://www.badcaps.net/forum/showthread.php?t=95925Comment
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM -
by EazyBoneThis TV turns on you see the Android logo it loads goes to home screen will stay on the home screen for about 30 seconds to a minute roughly and then clicks the relay on the PSU and shuts off.
It's a q LED and I've tested the LEDs to the best of my ability using the ribbons and an LED tester and they are all 22 volts on all three channels of the ribbon. I do know LEDs failing and cause this issue. I don't think it's this but maybe.
Have disconnected 3/4 on both sides of the ribbon and one half on each side of the ribbon and the entire panel itself. And it does the same...5 Photos -
by tomketczDoes anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
by Coolgoodman85” Hisense TV
Greetings,
Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
Dear TV technicians of forum, I hope this message finds you well.
I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight... - Loading...
