Haier Power Supply Board AY090D-4SF01
  • Nicktronic
    • Mar 2023
    • 247
    Re: Haier Power Supply Board AY090D-4SF01
    Alright, well, I went back and rechecked the LED strips (individually this time), and one strip had a bad (but working) LED....8vdc dropped across it. I didn't notice it the first time around cause the whole array worked.
    So thank you all for your help, I did learn alot about the power board circuitry which will be helpful in the future!
      • 12187
      • U.S.
      #42
      Glad you found the culprit, was a good refresher thread for me too, was able to put that backlight testing back into my memory, it fell out, hope it stays in longer this time.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
      • Nicktronic
        Samsung Power Supply Board BN44-00874F
        by Nicktronic
        Hey everyone,
        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
        Anybody...
        03-17-2025, 06:20 AM
      • penangit
        Hp v193 monitor power supply board
        by penangit
        Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
        I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
        I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
        Steps taken so far:
        Checked all...
        02-21-2023, 04:00 AM
