Philips Aurea 42PFL9900D/10
  • ageman
    • Oct 2015
    • 45
    • united kingdom
    Guys
    could anybody help. I have a Philips Aurea 42PFL9900D/10. I am trying to find information on the common issue of no display, but sound and Ambilight working. It has been repaired twice, but unsure of what would have been replaced. Tried looking online, but not much luck. Can't seem to find the correct schematics.
    Any help would be appreciated
  • lotas
    • Jan 2016
    • 4753
    • Russia
    Re: Philips Aurea 42PFL9900D/10
    CHASSIS Q528.1E LA
    https://elektrotanya.com/philips_42p...wnload.html#dl
      • 12276
      • U.S.
      can try a simple reset, with tv unplugged hold power button in on tv for 30 seconds then plug it in and try it, can also look around for a little hole on tv that says reset next to it, with tv plugged in stick a paperclip or the like in and hold it in til tv restarts, usually takes 30 seconds or less if it's going to work.
      • William1967
        • Nov 2017
        • 215
        • Netherlands
        Repair the backlight inverters, it's a common fault with this model.
          • 12276
          • U.S.
          did you shine a flashlight on the screen hit menu see if you see any text or anything?
          • ageman
            • Oct 2015
            • 45
            • united kingdom
            Hi don't have the inverter boards for modification
              • 12276
              • U.S.
              What do you mean, the tv came without inverter boards? The kit in post #4 is what you would buy and replace those components, which are: SCC_73709
              COMPONENT KIT (996500095005)
              The Component Kit includes the following components (for Master & Slave) :
              • TVS zener diode (33 V) x 2
              • MLCC capacitor (100 pF) x 2
              • Resistor (DIP type or SMD) 4.7 Ω x 4
              • ageman
                • Oct 2015
                • 45
                • united kingdom
                these inverter boards are not fitted in this set. The schematics for this chassis do not show these boards. I am confused lol
                  • 12276
                  • U.S.
                  I see, that's why it's important for faster solutions, if the thread starters, START with good straight on focused pictures of each board and one of the whole back as to see how everything is connected.
                  • ageman
                    • Oct 2015
                    • 45
                    • united kingdom
                    Hi Guys
                    Think I have found the issue, some baf ccfl lamps, and some bad contacts. Would anybody know where I could get replacement lamps?
                    TIA
                    Adrian
                    • dominik0801
                      Philips 55PFL6008K/12K Ambilight not working
                      by dominik0801
                      Hey,
                      I just got the TV mentioned in the title the other day.
                      Yes, I am well aware of it being a QFU chassis which is very hated - although I love QFUs (maybe for being this bad?), my main TV is a QFU too, and I bought this TV for this very reason.
                      It had the typical 2 blink error, which was fixed by a proper Fusion CPU reballing, with extra cooling mods. It works.
                      Everything is perfectly fine with it, but the Ambilight just won't do anything.
                      At all.
                      Won't work on Dynamic, won't work on Static. Not a single...
                      11-28-2022, 01:24 PM
                    • kew1701
                      Philips taw6205 ambilight speaker STM32 mcu dead
                      by kew1701
                      Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                      04-09-2025, 03:59 AM
                    • Vesko356
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • ahmedtou
                      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                      by ahmedtou
                      help me please
                      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                      I will share all the details with you, including the disc information.
                      Code:
                      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                      Current Profile: BD-R
                      Disc Information:
                      Status: Empty
                      State of Last Session: Empty
                      Erasable: No
                      Free Sectors: 12,219,392
                      Free Space: 25,025,314,816 bytes
                      Free Time: 2715:27:17 (MM:SS:FF)
                      Next
                      08-27-2025, 08:49 AM
                    • alro7779
                      Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                      by alro7779
                      Hello, guys!
                      The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                      09-14-2025, 12:25 AM
