Philips Aurea 42PFL9900D/10
  • ageman
    • Oct 2015
    • 45
    • united kingdom
    Guys
    could anybody help. I have a Philips Aurea 42PFL9900D/10. I am trying to find information on the common issue of no display, but sound and Ambilight working. It has been repaired twice, but unsure of what would have been replaced. Tried looking online, but not much luck. Can't seem to find the correct schematics.
    Any help would be appreciated
  • lotas
    • Jan 2016
    • 4554
    • Russia
    Re: Philips Aurea 42PFL9900D/10
    CHASSIS Q528.1E LA
    https://elektrotanya.com/philips_42p...wnload.html#dl
    • nomoresonys
      • 12104
      • U.S.
      can try a simple reset, with tv unplugged hold power button in on tv for 30 seconds then plug it in and try it, can also look around for a little hole on tv that says reset next to it, with tv plugged in stick a paperclip or the like in and hold it in til tv restarts, usually takes 30 seconds or less if it's going to work.
      • William1967
        • Nov 2017
        • 203
        • Netherlands
        Repair the backlight inverters, it's a common fault with this model.
        • nomoresonys
          • 12104
          • U.S.
          did you shine a flashlight on the screen hit menu see if you see any text or anything?
          • ageman
            • Oct 2015
            • 45
            • united kingdom
            Hi don't have the inverter boards for modification
            • nomoresonys
              • 12104
              • U.S.
              What do you mean, the tv came without inverter boards? The kit in post #4 is what you would buy and replace those components, which are: SCC_73709
              COMPONENT KIT (996500095005)
              The Component Kit includes the following components (for Master & Slave) :
              • TVS zener diode (33 V) x 2
              • MLCC capacitor (100 pF) x 2
              • Resistor (DIP type or SMD) 4.7 Ω x 4
              • ageman
                • Oct 2015
                • 45
                • united kingdom
                these inverter boards are not fitted in this set. The schematics for this chassis do not show these boards. I am confused lol
                • nomoresonys
                  • 12104
                  • U.S.
                  I see, that's why it's important for faster solutions, if the thread starters, START with good straight on focused pictures of each board and one of the whole back as to see how everything is connected.
                  • ageman
                    • Oct 2015
                    • 45
                    • united kingdom
                    Hi Guys
                    Think I have found the issue, some baf ccfl lamps, and some bad contacts. Would anybody know where I could get replacement lamps?
                    TIA
                    Adrian
                    • dominik0801
                      Philips 55PFL6008K/12K Ambilight not working
                      by dominik0801
                      Hey,
                      I just got the TV mentioned in the title the other day.
                      Yes, I am well aware of it being a QFU chassis which is very hated - although I love QFUs (maybe for being this bad?), my main TV is a QFU too, and I bought this TV for this very reason.
                      It had the typical 2 blink error, which was fixed by a proper Fusion CPU reballing, with extra cooling mods. It works.
                      Everything is perfectly fine with it, but the Ambilight just won't do anything.
                      At all.
                      Won't work on Dynamic, won't work on Static. Not a single...
                      11-28-2022, 01:24 PM
                    • kew1701
                      Philips taw6205 ambilight speaker STM32 mcu dead
                      by kew1701
                      Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                      04-09-2025, 03:59 AM
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • corrize
                      Where to find a very small fpc connector 0.3mm between 2 pins ?
                      by corrize
                      Hello, I search this connector (oxydated).
                      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                      Do you know how to find this connector please ? What is the exact name for find it ?
                      08-06-2024, 05:25 PM
                    • Diah
                      Philips 55PUS7304/12 Android Backlight & Ambilight ON, Blank Screen
                      by Diah
                      Okay, friends... i just won the bids on Ebay for this defect 4K TV. seller description backlight come on and the Ambilight too, but the screen remain black. no more info about the sound. photos attached from seller side..
                      my thinking its Firmware issue.. so right now i am working on to ready Android firmware to over write all section via USB. as PKG & FRCV with Thanks to Alex.. include:
                      Code:
                      tpv_nt315_2k19_isp.bin
                      tpv_nt334_2k19_data_isp.bin
                      tpv_nt334_2k19_isp.bin
                      upgrade_loader.pkg
                      with my hope my suspect in place LOL...
                      03-08-2021, 02:47 PM
