LC-60LE550U No Power
  • R_J
    • Jun 2012
    • 9515
    Re: LC-60LE550U No Power
    You measure the output of the bridge rectifier across its - and + pins. HS7001 is connected to the bridge negative via FB7003
    If by KIA you mean Q7120, that is a 4 pin regulator for PNL12V and is controlled by the main board. If you have 13vdc on its input there is a good chance the power supply is working, to get any voltage OUT of Q7120, you need to take the PNL_POW pin16 high
    • m4a2t0t
      • Mar 2013
      • 276
      If I put 5V on pin 16 I get 12V on the output.
      The rectifier reads 67V for middle pins and 15V across - and +
      • Davi.p
        • Sep 2009
        • 4266
        • Italy - Milan
        your battery of meter is kaputt.. the board is probably ok, must be loaded with resistor in 5v and car lamp on 13v
        • R_J
          • Jun 2012
          • 9515
          You don't seem to understand what a bridge rectifier does. The two inner pins ~ and ~ are where the AC is connected, The bridge rectifier then rectifies this AC into DC voltage across the + and -
          The BRIDGE RECTIFIER is BD7001
          Measure the AC voltage across the AC1 plug going to the board. You MUST change your meter from AC to DC to check AC voltage or DC voltage.
          What kind of meter are you using?
          • nomoresonys
            • 12081
            • U.S.
            Bridge rectifier checking by tampatec, thanks Vinceroger for reminding me when I completely forgot: https://www.youtube.com/watch?v=zK8oNhFaRdM
            • m4a2t0t
              • Mar 2013
              • 276
              I remember what a bridge rectifier is but for some reason I kept thinking everything on the primary side was in AC
              The proper reading are 406V on the large caps.
              Is the main board the problem?
              • R_J
                • Jun 2012
                • 9515
                All this means is that the PFC circuit IS working, so I suspect all the other voltages produced by the power supply are also there. Try disconnecting one of the flat white cables between the panel and the t-con board and see if you get anything on the panel, if not, reconnect it and try the same with the other cable. (don't remove or connect cables with power applied)
                • m4a2t0t
                  • Mar 2013
                  • 276
                  I see nothing on the screen when removing Tcon cables.
                  • R_J
                    • Jun 2012
                    • 9515
                    Are you getting any voltage on the PL plug on the t-con board?
                    • m4a2t0t
                      • Mar 2013
                      • 276
                      There is 12Vdc on the right 2 pins.
                      The mainboard is still disconnected from the psu but im using the mainboard side connector to add 5v and the tcon is still connected to the psu.
                      Im using a flashlight to look at the screen.
                      • Davi.p
                        • Sep 2009
                        • 4266
                        • Italy - Milan
                        #31
                        this is not the way of testing a tv, first must check if the power board is ok, how i have already explained, after this youvdaj disconnect tcon and watch if strange supply tensions persists..
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          03-31-2024, 02:12 PM
                          09-06-2024, 05:59 AM
                        • meraklinetx
                          Asus Z97-a power cycle, no boot no cpu voltage
                          by meraklinetx
                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                          05-10-2023, 06:08 AM
                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-12-2024, 02:15 PM
