Hisense 58H6550E - Freezes/Won't turn on
  • tmhobadcap
    • Apr 2019
    • 156
    • CANADA
    I have another tv to fix for my friend. It is a Hisense smart tv. After turning on, it will freeze or stuck on certain screens. However, when it is connected to a tv box, it will automatically connected to it and play without any problem. I wanted to go to the menu and reset the tv. But it just freezes before I reach the reset menu. I have tried the hard reset methods, but no luck. I guess the main board is with problem. Will reflowing one of the chip may fix the problem? If yes, which chip should I try reflowing?
    The followings are some videos showing how it freezes.
    https://www.youtube.com/watch?v=Sh-xR0Ijwck
    https://www.youtube.com/watch?v=DqNiLzmBSIA
    https://www.youtube.com/watch?v=g1FxQHt4Tgg
  • lotas
    • Jan 2016
    • 4865
    • Russia
    Re: Hisense 58H6550E - Freezes/Won't turn on
    This one (eMMC).
    • Diah
      • Feb 2013
      • 6573
      use hairdryer to warm up the emmc.. warm to hot Temp will make him servent for you.. no freez... then log in service menu ( not normal user menu ) and from there look after "Clear Chip" this is hard reset. hope it will help.
      • tmhobadcap
        • Apr 2019
        • 156
        • CANADA
        Thanks for your suggestions and advice.
        I have tried Diah's suggestion first using the hairdryer, but the tv still freezes after turning on.
        Then I tried the reflowing using hot air station. I set the temperature to 375 degree celsius because in my past experience I need to set to this temperature in order to remove leds from the led strips. After that, when turning on, I only get the Hisense logo appears for a few seconds as in the video https://www.youtube.com/shorts/xohI-g_V-vM. Did I set the temperature too high and damaged the chip? Or should I try higher temperature?
        • Diah
          • Feb 2013
          • 6573
          you caused BGA issue on emmc. try again with yours heat gun.. but you need to load heavy weight on emmc to keep it much it can stick at boards during the heat process,
          • tmhobadcap
            • Apr 2019
            • 156
            • CANADA
            I did the reflowing by blowing hot air from the top. You suggest to load some weight on the emmc. Then I think I should blow the hot air from the bottom side of the pcb (there is no components on the bottom side). What temperature do you suggest I should use? Will the heavy weight on the emmc absorb some of the heat and so temperature setting should be higher?
            • Diah
              • Feb 2013
              • 6573
              we dont know which kind of gun you are using... if its not for BGA rework. mean the hot air will be blowing with high pressure. and this matter caused shaking at the chip doesn't mater from top or from downside. thought the chip bed points distances between each less than 1/2mm . place weight will keep it in place however the air pressure high.
              250-280° will be fine.
              • tmhobadcap
                • Apr 2019
                • 156
                • CANADA
                My heat gun is as shown on the photo. Is it suitable for BGA rework?
                • Diah
                  • Feb 2013
                  • 6573
                  yes.. this is BGA gun
                  • tmhobadcap
                    • Apr 2019
                    • 156
                    • CANADA
                    As per Diah's suggestion, I should add heavy weight load to the chip while reflowing. Since it is so small, I could only think of pressing the chip with tweeters at the end of the reflowing. I tried several times (maximum temperature setting was 375°C but the results were just the same (Hisense logo appears for a few seconds). I found that the chip could not be moved at 375°C, so I thought may be the temperature was not high enough. I raised the temperature setting to 425°C and tried a few more times, but the results were the same. At 425°C, the chip could be moved and so I took the chip out hoping that cleaning the chip the pcb might help.
                    After removing the old solder, cleaning and adding new solder, I put it back. But the results were even worst, the tv could not be turn on (no Hisense logo, the standby light keeps red). Does this mean the chip has been damaged? Or putting back the chip must do "reballing" using solder balls and stencils as in some Youtube videos?
                    • Diah
                      • Feb 2013
                      • 6573
                      you did answered your question self.. if chips removed.. should only work---->
                      (("reballing" using solder balls and stencils))
                      • tmhobadcap
                        • Apr 2019
                        • 156
                        • CANADA
                        It seems that there are different sizes of solder balls and stencils. How can I know which size is for this chip?
                        • Diah
                          • Feb 2013
                          • 6573
                          by chip name / type you will find the right stencils include ball size
                          • tmhobadcap
                            • Apr 2019
                            • 156
                            • CANADA
                            From the codes on the chip, I can find the datasheet https://www.datasheets.com/en/part-d...0818#datasheet. But on the datasheet, I could not find the stencil size and ball size. Can you give me more hints on how to find the stencil size and ball size?
                            One more question. This chip was programmed by Hisense. But the one on the market is not programmed, therefore, I can buy one and replace the current one. Am I correct? Or if there is a way to program the chip? Or will Hisense sell this chip which is programmed?
                            • Diah
                              • Feb 2013
                              • 6573
                              use universal stensils . for example and buy also set of balls. you will need them at future... the chio are just 153 balls
                              first you rebll the original .. but if it die capacity reached 64Gb then nothing you can do only new one to put on... no need to program it.. CPU will boot TV and open USB port where you can flash firmware .. it will written on the new emmc.
                              • lotas
                                • Jan 2016
                                • 4865
                                • Russia
                                With a clean (empty without firmware) eMMC - the TV will not even turn on!
                                And in vain you heated eMMC to such a temperature, now even data cannot be read from it, they are afraid of overheating, especially "hynix". Along the way, you will have to look for a new motherboard.
                                • Diah
                                  • Feb 2013
                                  • 6573
                                  Lotas... this is android system.. with MT CPU. this cpu ready to open USB Port with key compination to load Firmware complete. ( Bootloader / recovery/ System).. also there are MT windows software with Service port terminal can write firmware.... on xda the software at section rooting media teck Smart TV
                                  • tmhobadcap
                                    • Apr 2019
                                    • 156
                                    • CANADA
                                    Like this post (https://www.aliexpress.com/item/1005...8da8sYbgY&mp=1), they have different diameter for the balls. Which one should I choose?
                                    • lotas
                                      • Jan 2016
                                      • 4865
                                      • Russia
                                      0.25mm.
                                      But solder paste is better.
                                      https://www.youtube.com/watch?v=9Aw8fEBJ_8Y
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4540
                                        • Italy - Milan
                                        Lotas, in your opinion Chinese market solder balls are low quality?
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • N3Star
                                          ASUS ROG G15 G513QY random freezes
                                          by N3Star
                                          My laptop recently started freezing randomly - it usually freezes after a few minutes, sometimes after 2, other times 10 minutes.
                                          So far I kind of ruled out software problems, as the problem persists on live booted Linux, installed Windows and also while installing Windows. My first thought was that it was overheating, so I checked the temps and they are fine, as You can see on the screenshot, never the less I opened it up and reapplied LM on both cores, also using some more thermal putty on the VRM, obviously didn't help.
                                          While live booting Linux it usually freezes...
                                          11-16-2025, 02:48 PM
                                        • sheffieldyorky
                                          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                          by sheffieldyorky
                                          Hey there people
                                          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                          This is what I tried, but not in any order.
                                          Google
                                          YouTube
                                          BIOS
                                          Command Prompt (administrator privileges)
                                          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                          10-25-2025, 02:22 AM
                                        • netgearnetgear
                                          JVC 40" LED TV (LT-40KC385) - Turning ON sometimes (stuck on loading, menu etc.)
                                          by netgearnetgear
                                          Hello esteem members,
                                          I have a JVC Television that fails to turn ON sometimes. The stand-by red light is always on. When the TV turns on the the JVC logo displays then the TV attempts to scan for local channels...it then freezes. If I unplug it, then it refuses to turn on - stand by light on. The power supply input voltages are present - 12V, with the backlight 0.32V when the TV refuses to turn on. Backlight voltage is 2.98V when TV does turns ON. All regulator chip has 3.3V on pin 8. Processor voltage - 1.02V, Ram - 1.5V. I am thinking about reflowing the on-board RAM. When the TV was...
                                          10-28-2023, 06:59 PM
                                        • notallbad
                                          Samsung UE55JU6000K stuck at 'Setup Conplete'
                                          by notallbad
                                          Reset the tv as internet connection not working, connected to router but no internet.
                                          Did a factory reset and completed the initial setup process but now just freezes on 'Setup Complete' page.
                                          Going into service menu it says 'Failure' at the top of the page and unable to access the 'control' screen.
                                          Its already on T-HKM6DEUC1570.0 fw.
                                          Are the SVC reset options likely to help here?
                                          options are
                                          apps reset
                                          svc reset
                                          spi flash reset
                                          data sync reset
                                          Any help appreciated.
                                          08-26-2023, 10:44 AM
