Samsung 32in LCD LA32A650A1FXXY
  • michael1973
    • Oct 2020
    • 6
    hi guys, i used the search function and couldn't find anything useful, if you know of something please post a link.
    i have an older samsung 32in Lcd:
    Model: LA32A650A1F
    Model code: LA32A650A1FXXY
    Type: LA32A650
    Power board: BN-4400208A
    Main board: BN94-01767A
    Problem is the Tv takes up to 6 power button led flashes to turn on, if it even turns on at all, the 5v standby voltage is solid the whole time, but when switching on the other voltages 12 and 24etc, they turn on and off (cycling about 1-2seconds) seemingly with the flashing led, when it finally turns on the power board voltages are stable and correct, i've disconnected all the other boards other than the main board and problem persists, i've disconnected everything except mains power and used the 1k resistor across pin 1 and 3 on the power board to power it on and all (5,12,24etc) the voltages are stable straight away.
    Only thing i noticed is if i leave the backlight board connected and manually power the power board with the resistor the backlights don't turn on, it must get a signal from elsewhere.
    I've removed and tested every cap on the power board and back light board, all test good via capacitance meter and esr meter. I have an oscilloscope for testing, but a beginner at that also, Id appreciate any advice.
    • 12330
    • U.S.
    Re: Samsung 32in LCD LA32A650A1FXXY
    see if one of the pins is labeled blu-on, bl-on, add another resistor there and you should get the backlights on, if working.
    • michael1973
      • Oct 2020
      • 6
      Thanks for the tip nomoresonys, i'll check it tonight
      • michael1973
        • Oct 2020
        • 6
        when i connect b/l and Det5v on the power board the backlight turns on immediately and all voltages appear stable, i have found a tiny cap on the mainboard that's measuring 6ohms on the ESR meter, but having trouble decoding 8B 1 50J, i have recorded some voltages for the the cycling issue starts for tomorrows test, it's not repeatable other than waiting a day. thanks for your help
        • michael1973
          • Oct 2020
          • 6
          update: i took the 1uf 50v cap off the board and measured in spec, put it back on.
          i did notice that the on/off pin on the power board which is the same pin i bridge from 5v with the 1k resistor, it measures 3.3v when the tv is on, but cycles when the tv is in the faulty cycling mode from almost zero to 3v (this connector goes to the main board), kind of leads me to
          think the main board is faulty here, what’s your opinion?
            • 12330
            • U.S.
            yes, I think you are correct, sure seems to be the mainboard at fault.
            • michael1973
              • Oct 2020
              • 6
              i was able to get the same tv and swapping boards im able to confirm it was the main board at fault, im looking for a thermal camera to try and narrow the specific fault on the board further
                • 12330
                • U.S.
                Ok, now that you have a working board you can compare some voltages between the two boards, should make it a lot easier to sort out.
                • Cooperr
                  Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                  by Cooperr
                  I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                  The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                  10-21-2025, 01:11 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • repair-it
                  Need advice testing a samsung power supply board with scope
                  by repair-it
                  I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                  07-12-2025, 11:00 AM
                  by sam_sam_sam
                  After all of...
                  07-13-2024, 08:14 PM
