magnavox / philips 26mf231d
  • Stlpheonix
    • Aug 2010
    • 4
    when i plug it in it will turn on and turn right back off imediately if i hit the power button it will do the same anything you can suggest would be great thanks alot
    STLPheonix
  • Stlpheonix
    • Aug 2010
    • 4
    Re: magnavox / philips 26mf231d
    also i have noticed that on the right hand connector on the power supply board the number 2 pin is burnt and the wire that connects to it is burnt a bit too.. any info you can help me with would be much appreciated
    stlpheonix
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Pictures, pictures and more pictures. Just enough to let us see what is going on here. I just want to start off by saying again - I HATE PHILIPS/MAGNAVOX. Ok, now that I got that out of my system. Please take some pics of the affected board and some of the exact area - connector. Sometimes a loose connector will arch to the board causing a buildup of carbon on the pins.
      • Stlpheonix
        • Aug 2010
        • 4
        ok here is the two pictures the first is of the board it self the second is the only thing that looks burnt (the pin #2) and
        • AJ11R83
          • Aug 2010
          • 19
          try uploading your pics to www.photobucket.com :-)
          • Wrog
            • Oct 2009
            • 472
            Or better yet, just click the "Manage Attachments" button when replying and upload.
            • AJ11R83
              • Aug 2010
              • 19
              oh dear.... iv never noticed that ya know!
              • Stlpheonix
                • Aug 2010
                • 4
                sorry about that dont know what i was thinking lol
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  Yeah the "Manage Attatchments" is the preferred method by this forum.
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • tonybig10
                    Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                    by tonybig10
                    Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                    the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                    03-07-2025, 01:03 PM
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    Today, 12:54 PM
                  • aidanmo
                    Philips 43PUS7506/12 - Loud blown out sound
                    by aidanmo
                    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                    I thought maybe the speakers got damaged, so I replaced them - no dice.
                    • Using the internal speakers, it always happens.
                    • Using the headphone jack, it never happens.
                    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                    02-28-2025, 03:13 PM
                  • Cornito
                    Philips 50PUH6400 bad color and gosting / slow motion on one side
                    by Cornito
                    Hello Team,
                    New issue on LCD panel where I need to find out the cause and the potential solution.
                    This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                    I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                    When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                    I've checked voltages, no issue found comparing right and left side of the panel driver.
                    VHG VGL CKV... are the sames on...
                    03-08-2024, 06:41 AM
