magnavox / philips 26mf231d
  • Stlpheonix
    • Aug 2010
    • 4
    when i plug it in it will turn on and turn right back off imediately if i hit the power button it will do the same anything you can suggest would be great thanks alot
    STLPheonix
  • Stlpheonix
    • Aug 2010
    • 4
    Re: magnavox / philips 26mf231d
    also i have noticed that on the right hand connector on the power supply board the number 2 pin is burnt and the wire that connects to it is burnt a bit too.. any info you can help me with would be much appreciated
    stlpheonix
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      Pictures, pictures and more pictures. Just enough to let us see what is going on here. I just want to start off by saying again - I HATE PHILIPS/MAGNAVOX. Ok, now that I got that out of my system. Please take some pics of the affected board and some of the exact area - connector. Sometimes a loose connector will arch to the board causing a buildup of carbon on the pins.
      • Stlpheonix
        • Aug 2010
        • 4
        ok here is the two pictures the first is of the board it self the second is the only thing that looks burnt (the pin #2) and
        • AJ11R83
          • Aug 2010
          • 19
          try uploading your pics to www.photobucket.com :-)
          • Wrog
            • Oct 2009
            • 472
            Or better yet, just click the "Manage Attachments" button when replying and upload.
            • AJ11R83
              • Aug 2010
              • 19
              oh dear.... iv never noticed that ya know!
              • Stlpheonix
                • Aug 2010
                • 4
                sorry about that dont know what i was thinking lol
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  Yeah the "Manage Attatchments" is the preferred method by this forum.
                  • G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                    by G33RT
                    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                    It does power up when pressing the power button.
                    I already try the power button while plugin the plug with no result.
                    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                    Could this be an PSU or eMMC issue ?
                    07-19-2025, 03:43 AM
                  • tonybig10
                    Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                    by tonybig10
                    Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                    the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                    03-07-2025, 01:03 PM
                  • double_DD
                    Philips curling iron - is this a common AC cable?
                    by double_DD
                    Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                    As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                    Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                    08-18-2025, 10:04 AM
                  • janos6662000
                    Philips 47PFS7509/12 LCD TV problem
                    by janos6662000
                    Hi
                    I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                    When i applied cable signal to check image, i had normal picture, but TV was restarting.
                    I downloaded original firmware and applied the update, but the problem remained.
                    From a colleague i received a "factory package software" which is a lot bigger.
                    I made another firmware update, but still did not solve the problem.
                    Somewhere on the way the error got worse, because at the moment the...
                    08-12-2025, 12:54 PM
                  • aidanmo
                    Philips 43PUS7506/12 - Loud blown out sound
                    by aidanmo
                    I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                    I thought maybe the speakers got damaged, so I replaced them - no dice.
                    • Using the internal speakers, it always happens.
                    • Using the headphone jack, it never happens.
                    • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                    02-28-2025, 03:13 PM
