Samsung 55KS8005TXXE power cycling
    • 12330
    • U.S.
    Re: Samsung 55KS8005TXXE power cycling
    did not see your exact model but more testing there: https://www.youtube.com/watch?v=Aes6WiG2044
    • baldharry
      • Jan 2023
      • 17
      • .fi
      its tough, here's a little of what Tampatac went thru, I can't see if he made another video on this tv or not, last thing he says I think, is that he's going to try to fix the mainboard but I don't see the next video, he may have gave up, not sure: https://www.youtube.com/watch?v=-_e9DFeZYKI
      Diah or Lotus might have a better idea on whats wrong, mainboards are not an easy tackle.
      Ok thanks, I'll have a look.
      So strange that both mainboards act the same... The mainboards do look intimidating for sure
      • Storyteller12
        • Jun 2020
        • 625
        If the tv won't stay on with the lvds cables disconnected from the panel then the only thing it can be is the main board. There is no tcon. If the backlights come on when the mainboard is unplugged then the power supply and backlight is good.
        Don't order from Ali express. Try eBay and Ali express as a last resort.
        • Storyteller12
          • Jun 2020
          • 625
          • baldharry
            • Jan 2023
            • 17
            • .fi
            Yes, that is what happens as you described.
            Aliexpress was the only place to find a matching board $46 for the board, not that much of a loss. But now for a special price, only for you, a Samsung 55KS8005 carcass for $46. Only pickup, will not send
            • baldharry
              • Jan 2023
              • 17
              • .fi
              #26
              Found this on another forum:
              Question about the power cycling on this TV that others have experienced. They have replaced the main board on this and it did'nt fix the issue and now they are replacing the power board. My extended warranty is expiring soon and wanted to know if it's worthwhile for $75 for another year of service or not. Should replacing the power board fix this issue or is there something else that may come up later making it wise to extend the warranty.
              Because my two mainboards make the TV behave "identically", is it the PSU to blame afterall...
              • Storyteller12
                • Jun 2020
                • 625
                Take voltage measurements and compare with the legend on the board. But as I mentioned if the backlights come on when mainboard is disconnected that shows the power supply is good.
                Your going down the rabbit hole now. Lol
                • lotas
                  • Jan 2016
                  • 4856
                  • Russia
                  #28
                  Or maybe the panel is faulty. For some modern Samsung models, the TV will not start if the panel is not working and if you disconnect one or two LVDS loops, then it will not start either, you need to set jumpers on the motherboard (T-Con) to simulate the panel (as if it is connected).
                  • baldharry
                    • Jan 2023
                    • 17
                    • .fi
                    #29
                    Oh, that's interesting! How do I know which pins to jump?
                    • lotas
                      • Jan 2016
                      • 4856
                      • Russia
                      #30
                      The signals "FB_TRDY" are responsible for the simulation, you need to connect all the loops (not including the TV in the socket) and measure these points between each other with a multimeter (for continuity), then turn off one loop and measure again and draw a conclusion where the jumper is placed, mainly between FB_TRDY_1 and FB_TRDY_3.
                      • Devil_rider
                        • Jan 2023
                        • 33
                        Does this look like your psu?
                        • baldharry
                          • Jan 2023
                          • 17
                          • .fi
                          #32
                          Thanks lotas, will try.
                          @Devil rider, yes. Except that the resistors basecolor is different, those are green, on mine pinkish or more maybe like pig skin. And thermistors, green on yours and black on mine.
                          • baldharry
                            • Jan 2023
                            • 17
                            • .fi
                            #33
                            Oh almost forgot. Noticed that after TV has been in standby for a while, the voltages drop. For example, the Vamp and stby voltages drop down to 8.99 volts. That shouldn't be happening?
                            • Devil_rider
                              • Jan 2023
                              • 33
                              There should be a 9000 series technical guide in which you might find the bypass and simulation procedure. The 2 series are almost identical.
                              • valvashon
                                Samsung UN55FH6030: random power cycling
                                by valvashon
                                Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
                                About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
                                Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
                                10-20-2023, 09:59 AM
                              • high-tech
                                Samsung UN55F7050AFXZA ver. TD01 power cycling
                                by high-tech
                                Hello everybody, I could use some help on this one... It's got me guessing...
                                I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                9. ground (PWM2) 10. 0.9 volts cycling...
                                09-15-2020, 03:39 PM
                              • mrtek
                                Samsung UN43NU6950FXZA No power
                                by mrtek
                                Hi
                                Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                Main fuse = OK
                                Back light LED = OK. Power them with aux power source
                                LED output = OK 156V
                                I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                07-20-2025, 08:06 PM
                              • Capacitorial
                                Powersupply has all the voltages - Monitor still no power
                                by Capacitorial
                                Hello guys,
                                I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                The weird thing is, that the Power LED is powered over the TCON board.
                                On The TCON...
                                12-28-2024, 02:12 PM
                              • MrBrick
                                Samsung UE55RU8000 power cycling (turning on and off)
                                by MrBrick
                                I've owned this tv for 3 years when all of a sudden it started power cycling - with no apparent cause. It's not in warranty.
                                I know this appears to be a fairly common issue, but would appreciate some guidance as I have no idea what i'm doing.
                                I have taken the back off and when either of the two ribbons connected to the main board are disconnected, no image other than the back light appears on the screen, but the sounds runs. This happens with both ribbons and when they are both in place, the power cycling starts again.
                                Is there any recommendations on...
                                10-23-2023, 07:59 AM
