LG 70UH6350 (UB.BUSMLJr)
  • nonsub
    • May 2018
    • 84
    Re: LG 70UH6350 (UB.BUSMLJr)
    Originally posted by nonsub
    So if I am reading right then P803 anodes are joined pin 7+8 right?
    Oh nvm I see the trace connects big
    • Diah
      • Feb 2013
      • 6371
      yes.. P801 / P802 ( 1+2) P803 (7+8) all are one line... si just plug the BL socket in place and take any one of ÖED+ as probe and messure against other VC 1-12
      • nonsub
        • May 2018
        • 84
        Originally posted by Diah
        they look all 3 sockets led+ are connected together
        if this case then take one as anode probe and measure all other vc .. write down the result
        OK sorry Vc = Voltage Cathode yes (-)
        I am doing this with BL forced on yes (I guess no other option would make sense lol.) Also mobo disconnected?
        • Diah
          • Feb 2013
          • 6371
          lol yes my typo... correct 7-8... there are no 9 at all
          • Diah
            • Feb 2013
            • 6371
            the VC 1 to 12 you can use this hols to measure.. more easy than the socket
            • nonsub
              • May 2018
              • 84
              I was hoping we would find a problem here but all 12 are 96.1V and 97.1V
              • Diah
                • Feb 2013
                • 6371
                do it again.. now with ref. TV chassis
                • nonsub
                  • May 2018
                  • 84
                  Sorry just LED+ to chassis so only one reading right?
                  • Diah
                    • Feb 2013
                    • 6371
                    black probe on chassis.. and red on vc 1 to 12
                    • nonsub
                      • May 2018
                      • 84
                      ok just to be clear previously I did red on LED+ and black on 1-12.
                      also incase needed red to LED+ and black to chassis = ~98V
                      • Diah
                        • Feb 2013
                        • 6371
                        just do this please ..... black probe on chassis.. and red on vc 1 to 12
                        • nonsub
                          • May 2018
                          • 84
                          all between 1V an 2V.
                          • Diah
                            • Feb 2013
                            • 6371
                            ????? are you sure... check again
                            • nonsub
                              • May 2018
                              • 84
                              Voltage jumps around a lot 0.99V - 2V.
                              OK will do again now.
                              • nonsub
                                • May 2018
                                • 84
                                They all settle around 1.4V - 1.7V it seems but Vc_8 bounces up to a peak of 2.2V and settles around 1.9V-2V
                                • Diah
                                  • Feb 2013
                                  • 6371
                                  yours DMM set on DC right... and level 100V DC correct.. if yes,,
                                  you need to do this test again.. after setting the probe.. you turn on the PWB.. and ckeck the high and low... see if only VC8 play crazy reading
                                  • nonsub
                                    • May 2018
                                    • 84
                                    DMM is auto-ranging (not sure if can disable)
                                    Sorry power is on the whole time with black to chassis. Then I probe each of 12. Am I doing this wrong?
                                    • Diah
                                      • Feb 2013
                                      • 6371
                                      no this wrong, need to each time after set the probe on vc power up the PWB and remark the high and low
                                      • nonsub
                                        • May 2018
                                        • 84
                                        OK sorry so set to 100V range lol.
                                        All are 1.1V-1.6V but VC8 1.9V-2.0V
                                        • Diah
                                          • Feb 2013
                                          • 6371
                                          ?? dont hurry.. read my last post
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Mirenia
                                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                            by Mirenia
                                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                            03-30-2025, 06:47 AM
