LG 70UH6350 (UB.BUSMLJr)
  • nonsub
    • May 2018
    • 84
    Re: LG 70UH6350 (UB.BUSMLJr)
    This TV is from hell
    Replaced mainboard again and exactly the same Only difference is now only sometimes Toslink light goes on but I think I had this also with other board (seemed random.)
    • nonsub
      • May 2018
      • 84
      I'm thinking if these have a high failure rate and the 3 I have bought so far are like "last 1 in stock," maybe I keep getting bad ones? Like we have seen the backlight and all pixels light up so impossible to be something else? I will double check all voltages @ mainboard side.
      • Computeman
        • Sep 2015
        • 3
        • usa
        #63
        Shorted TFT display
        Last edited by Computeman; 02-16-2023, 10:14 PM. Reason: Shorted TFT display missed the posted panel pix
        • nonsub
          • May 2018
          • 84
          Originally posted by Computeman
          Shorted TFT display
          Hey CM. I just saw your backlight tester post then this edit.
          Have you seen the pics I posted though where I am able to lightup all pixels (1/2 screen at a time?) Wouldn't that be not possible if a short? Also DIAH's panel ribbon disconnecting tests...
          Also shouldn't mainboard boot properly (ie. PC seeing the HDMI, maybe ethernet port working?)
          A
          • Diah
            • Feb 2013
            • 6365
            nothings impossible... but since now replacment MB under hand. please do the following
            Remove Load...
            1- disconnect all 4 ribbon between T-CON & LCD from T-CON side and never connect them again until you finish trouble shooting
            2- same to WIFI /BT Module disconnect them
            3-put yours DMM Probe always on T-CON Fuse F1 to remark the 12V
            4- Insert USB pen with any kind of media content at any USB Port. prefer with LED Indicator to know if it blinking during start ( we need to know the DC-DC Circuit on MB produce USB 5V.
            4- Plug the tv in wall socket. at time TV start (Toslink light goes on ) plug the TV from wall socket.. and never use the RC AGAIN::: to make us sure the MB registered the Last state mode ( mean always when you plug it at wall will start.. an not goes to STB )
            5- please record movie on yours MB during this test and upload it here.. and tell the result about T-CON 12V.
              • 12181
              • U.S.
              #66
              cant remember if did this test, did you get a solid toslink light with any of the mainboards, with the cable from mainboard to panel unhooked, unhook it at the mainboard, less chance of any cable ends accidentally shorting out with incidental metal contact.
                • 12181
                • U.S.
                #67
                still makes me wonder if maybe at least one of those mainboards are good and something else is wrong??
                • nonsub
                  • May 2018
                  • 84
                  1 board yes Toslink goes solid reliably when using remote standby > on.
                  Latest board seems to only occasionally have Toslink go on when switching out of standby.
                  • nonsub
                    • May 2018
                    • 84
                    I need a headmount camera or something, too hard to film with one hand but will try. But I can answer these for now.
                    Remove Load...
                    DONE
                    DONE
                    DONE
                    NO 5V ever in any state any board. Tested both with USB stick and DMM.
                    Board 1
                    Plug in = solid red = standby = no Toslink. Button or RC out of standby = Toslink on. Toslink always off in standby on out of standby.
                    Board 2 (arrived yesterday, different board version.)
                    Toslink seems random and mostly off. Can't figure out any pattern/reproduce. Update - it does seem like it goes on one time the firsy exit standby but then can't go on again until unplug for several minutes.
                    All boards last state never registered; always standby when unplugged 10 seconds plugged back in.
                    All boards = TCON near 12V always in out of standby, 0v standby.
                    Thanks!
                    • nonsub
                      • May 2018
                      • 84
                      So my thought is since it seems unlikely that original board failed and then 3 more were DOA it seems possible that the boards were good but something killed them right away.
                      Since PSU measurements seem all OK and we have lit backlight OK and also all pixels (half a screen at a time) it seems like TCON, TCON to panel pcb and panel are OK. PSU to MOBO cable seems OK too so this leaves only switch ribbon cable and the 2 X motherboard to TCON. So I will check for shorts there... if there are then this could fry every board maybe? Nope checked w/microscope at least all wires seem ok.
                      • Diah
                        • Feb 2013
                        • 6365
                        there are SOS signal come some where to MB.. i would suggest back to point where you did the test with external 3.5V to run the PWB as stand alone.. with out MB.. and measure all yours BL socket pins ... any group it should have same current Value.. if there are different mean this group had shorted LED. you need to be sure of this.. because when they lit on with just the way you did.. doesn't mean they are okay.... and also when you force them to on... the protect circuit which send SOS to MB will be disabled or over loaded too because MB disconnected at the test.
                        • Storyteller12
                          • Jun 2020
                          • 624
                          If I recall correctly my mainboard that was bad had a bunch of shorted caps. Not positive. It I think it was he main processor that went bad.
                          Test caps on mainboard for shorts
                          • nonsub
                            • May 2018
                            • 84
                            OK thanks. For doing this without removing back from panel do I need to buy LED tester or I can do just with DMM?
                            • Diah
                              • Feb 2013
                              • 6365
                              only with DMM... read the print chart of each socket ( printed on PWB) to know the Anoden and it related Pins.
                              • nonsub
                                • May 2018
                                • 84
                                OK cool thanks. Would you mind explaining what and how to exactly test sorry?
                                I think you will have me test with the BL ribbon connectors connected but use the pins of the connectors to test (I have some hook leads.) But not sure what I'm testing just the LED+ pins while tricked on?
                                • Diah
                                  • Feb 2013
                                  • 6365
                                  okay... first look at the PWB socket from down side.. see for example socket P801 if the LED+ 1 & 2 are connected together at circuit. or separated
                                  • nonsub
                                    • May 2018
                                    • 84
                                    Is this thread here?
                                    https://www.badcaps.net/forum/showthread.php?p=1131857
                                    Also on a youtube video but the person did not bother to warn against cutting the safety wire as a permanent solution.
                                    These particular boards through do not have that line on the power connector though it seems.
                                    • nonsub
                                      • May 2018
                                      • 84
                                      So I am not sure how pins are numbered. I see from a overhead view oriented as picture that pin 1 on each is the upper right. But is pin 2 on the row under or would it be adjacent left?
                                      • Diah
                                        • Feb 2013
                                        • 6365
                                        Here pic. I will figure out the answer.
                                        they look all 3 sockets led+ are connected together
                                        if this case then take one as anode probe and measure all other vc .. write down the result
                                        • nonsub
                                          • May 2018
                                          • 84
                                          So if I am reading right then P803 anodes are joined pin 7+8 right?
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Mirenia
                                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                            by Mirenia
                                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                            03-30-2025, 06:47 AM
