LG 70UH6350 (UB.BUSMLJr)
  • nonsub
    • May 2018
    • 84
    Re: LG 70UH6350 (UB.BUSMLJr)
    To be clear... removed U ribbon completely on left side, tested, no diff. Put back on and removed U ribbon from right. Same thing exit standby = 3 flashes. No BL at any point. Button on TV loses function but remote power button still takes in and out of standby.
    Also sorry but If I connect HDMI signal it will default select it?
    • nonsub
      • May 2018
      • 84
      Yes so connected HDMI to PC. Normally Windows will detect the HDMI audio connection but does not. Does this not prove that motherboard is bad?
      • Diah
        • Feb 2013
        • 6365
        at this case.... disconnect the panel complete from T-CON.. ( disconnect the 4 ribbon from T-CON side.... tv in normal case work with out Panel in place )... and work first on MB.. its suspected. BGA or NVM / SPI./NOR.
        3Flash by LG also tell if there are some where short include BL
        also you can do it as you wrote at first post... MB disconnected and run the PCB stand alone...
        LVDS between MB - T-CON disconnected.... panel connect to T-CON
        feed from PCB 12V line direct to the T-CON fuse
        turn on and check what you will have on screen... and if the 12V drop down or not
        • nonsub
          • May 2018
          • 84
          Thanks again for all the time trying to help.
          Yes I believe MB is the problem even if 2 x boards (original + E-pray board.) But I am scared to spend 200 $USD + shipping without knowing for sure
          OK but I see full backlights when I give 3.5V to DRV_ON so this proves BL is ok?
          I also have a cheapo BL tester but I think it would be hard to test on ribbon...
          When you say PCB I assume you mean the power board? OK so with MB disconnected I must trigger PWR_ON with 3.5V. I take also 12V to fuse on T-CON. Other side of fuse I read ~12V and nothing on display
          • Diah
            • Feb 2013
            • 6365
            1- trigger PWR_ON & DRV_ON with 3.5V. I take also 12V to fuse on T-CON
            2-the way you tested and BL come on.... yes you have light can see.. but the protection circuit which monitor and send signal to MB are disabled ( MB disconnected )
            • Diah
              • Feb 2013
              • 6365
              then nothing left only Dirty Test
              all cable boards / panel connected at it should.
              ONLY on power boards socket to MB. clip out from socket only the wire line of DRV_ON, and trick the pin on the socket with 3.5V as you did before... turn on and check what do u have on MB and screen ... measure V on T-CON too.
                • 12181
                • U.S.
                #27
                well could try another mainboard, maybe get one from a seller that will accept returns if the board doesn't cure the issue.
                  • 12181
                  • U.S.
                  #28
                  are you sure tv is direct lit? sams club says edge, kinda looks too thin to be direct lit.
                    • 12181
                    • U.S.
                    #29
                    did you ever notice what level you were running the backlights on, such as vivid which is full blast, were they turned all the way up to max?
                      • 12181
                      • U.S.
                      #30
                      Thank you. OK I will check this but this is also the second tcon board.
                      If blacklists go on when manually 3.5v drv and our on they are for sure good or could still be the problem? I ask because I see another thread on this unit that this board will not boot if backlight problem and to cut safety wire to test (but where us safety wire?)
                      Thx
                      Is this thread here?
                      • nonsub
                        • May 2018
                        • 84
                        Yes sorry you must be correct. For some reason I thought local dimming had to be direct of FA.
                        Looking at your other kind replies... reminds me of one of the (many) youtube vids I checked... in that case it seemed like full brightness was drawing too much and the guys solution was to cut the SAFE (I think called) line and all was good (which does not seem like a good idea lol.) Anyway this PCB doesn't seem to have such a thing. I've never adjusted brightness TBH.
                        See next post I've a good update!
                        thanks again!
                        • nonsub
                          • May 2018
                          • 84
                          I feel like we are getting somewhere now!!!
                          You know this was a test I did before this but did not jump the 12V to TCON and also it seems to me that I also needed to cut the PWR_ON line. Maybe this is wrong though and I missed a connection.
                          Anyhow so now we have these results:
                          Power board to MOBO = cut PWR_ON, DRV_ON, feed 3.5V
                          Power board to TCON fuse = jump 12V
                          I get various results from disconnecting different TCON > PANEL ribbons.
                          I can get half of screen lit white at a time but not both together. It seems like the middle two TCON > PANEL ribbons do this.
                          No difference if MOBO is completely removed or connected.
                          So I think we are pretty clear that MOBO is definitely bad?
                          Are we near 100% that all other components are good or is there more TCON testing to do?
                          • Diah
                            • Feb 2013
                            • 6365
                            i think i wrote only DrV_on to take out.. MB Power on signal are fine as i read from yours first post... so why you ignore it!!! bad
                            and no need to feed T-CON with 12V in this test..
                              • 12181
                              • U.S.
                              #34
                              well I don't know exactly but theres a tcon I think will work if it could be the problem: https://www.tvpartstoday.com/RUNTK56...tk5655tpza.htm
                              • Diah
                                • Feb 2013
                                • 6365
                                i am talking not early test... my talking on DIRTY TEST.
                                • nonsub
                                  • May 2018
                                  • 84
                                  Thanks but this is the second TCON lol.
                                  • nonsub
                                    • May 2018
                                    • 84
                                    OK will do. What do you want me to check on the MB though?
                                    thx
                                      • 12181
                                      • U.S.
                                      #38
                                      ok, after Diahs test, maybe put the other tcon in and see if you get the same results as in post #32, if you haven't tried both tcons for that test yet, interested to see if they both give the same display.
                                      • Diah
                                        • Feb 2013
                                        • 6365
                                        his T-CON working... and he will get same result even new t_CON from Factory.... no signal mean half buffer.. line etc. photo 1 photo2
                                        thx
                                        nothings just do as i wrote before and here again..
                                        every things connected as it should even the panel riboon all in place.
                                        only DRV_ON cable at PCB socket cut it off and feed its pin with yours external 3.5V
                                        check screen and check T-CON if the MB feed it 12V or not...
                                        my way to find the fult at MB to repair it if you can of course....
                                        • nonsub
                                          • May 2018
                                          • 84
                                          OK so did exactly as advised:
                                          As usual power button takes out of standby one time but then has no function.
                                          RC power goes in and out of standby as before.
                                          Each standy/exit standby = BL and random lines display/flicker like pics. Also lines "jumping" 11.5V @ TCON
                                          • Michael Long
                                            No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            by Michael Long
                                            I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                            Dead / No Power / No Standby Light results after power company had three
                                            consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                            After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                            09-13-2022, 06:55 AM
                                          • noinimod
                                            Sony 55X900E no standby light, no power. Replaced mainboard already
                                            by noinimod
                                            No standby red light, nothing
                                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                            At a few pins I can see the power supply providing 19.5V to the main board
                                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                            12-22-2021, 12:58 AM
                                          • stylishconsultant
                                            un60j620dafxza - Samsung No Display Problem
                                            by stylishconsultant
                                            Hi All,
                                            Need help.
                                            I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                            So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                            problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                            might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                            09-04-2024, 03:26 AM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
                                          • Mirenia
                                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                            by Mirenia
                                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                            03-30-2025, 06:47 AM
