Philips 43PUS6501/12 EEPROM request.
  • unimatrix93
    • Oct 2021
    • 347
    • Magyarország
    Hello everyone!
    Does anyone have a dump file for this model of TV?
    Motherboard number is: 715G7772-M01-B00-005K
    EEPROM IC: 25L1606E
    My TV is stuck in cycling color mode and I can't get out of it.
    I tried to erase the IC but it didn't help.
    Thanks in advance!
  • lotas
    • Jan 2016
    • 4651
    • Russia
    Re: Philips 43PUS6501/12 EEPROM request.
    715G7772-M01-B00-005K (Philips 49PUS6561/12)
    • unimatrix93
      • Oct 2021
      • 347
      • Magyarország
      Thanks man, you are the best!
      Will report back with the results.
      • lotas
        • Jan 2016
        • 4651
        • Russia
        There is also a dump from 43PUS6501-12 MAIN 7115G7772-M0D-B00-005K if needed.
        • unimatrix93
          • Oct 2021
          • 347
          • Magyarország
          Awesome, drop me that one too If you can please. It's a 43 inch model so maybe it would work better.
          Thanks again!
          • lotas
            • Jan 2016
            • 4651
            • Russia
            Originally posted by unimatrix93
            awesome, drop me that one too if you can please. It's a 43 inch model so maybe it would work better.
            Thanks again!
            43pus6501-12 main 7115g7772-m0d-b00-005k
            • unimatrix93
              • Oct 2021
              • 347
              • Magyarország
              I flashed it on the EEPROM IC but still no luck. It's still cycling colors
              • Diah
                • Feb 2013
                • 6397
                yours issue damaged LVDS Pins
                • William1967
                  • Nov 2017
                  • 214
                  • Netherlands
                  I guess you have an LG panel with an open cell t-con, when there is no signal detected from the mainboard the t-con goes in a WRGB mode.
                  • unimatrix93
                    • Oct 2021
                    • 347
                    • Magyarország
                    I checked on the LVSD cable and the little notches on the side is torn off. The pins looks all intact both on the cable and in the sockets. Maybe without the notches its slides in the connector and by it makes it shorting/wrong contacts?
                    • unimatrix93
                      • Oct 2021
                      • 347
                      • Magyarország
                      I'm not sure about the panel, but you are probably right.
                      • Diah
                        • Feb 2013
                        • 6397
                        show us clear photo of yours LVDS End from both side
                        • unimatrix93
                          • Oct 2021
                          • 347
                          • Magyarország
                          Here are some close ups. I noticed a small bit of contact is missing from the smaller cable end.
                          • Diah
                            • Feb 2013
                            • 6397
                            try Jumper the lost pin with extra thin cable from board to board. and clean the socket.. it could be the reset of the pins doing short some where
                              • 12206
                              • U.S.
                              Nice work Diah, you solved it with one post.
                              • unimatrix93
                                • Oct 2021
                                • 347
                                • Magyarország
                                Thank you for the advice, will try it with some enameled copper wire If I can find some.
                                • William1967
                                  • Nov 2017
                                  • 214
                                  • Netherlands
                                  Replace both cables and never use cables without the nodges!!! If not placed correctly centered there could be a S/C.
                                    • 12206
                                    • U.S.
                                    plus 100, don't risk shorting things out, just get some new cables.
                                    • my2k2
                                      Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                      by my2k2
                                      Good day to every one,
                                      I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                      Does anybody have an eeprom dump file? I really appreciate any help.
                                      Thanks in advance.
                                      07-01-2024, 09:04 PM
                                    • SidneyCanadas
                                      93C46 and 93C56 EEPROM
                                      by SidneyCanadas
                                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                      06-14-2023, 01:16 PM
                                    • Biruslapio
                                      Reprogram Philips 32PFL3008D Winbond EEPROM with ATMEGA328P
                                      by Biruslapio
                                      I've shearched before posting this, and found dozens of different ways to hook up multiple types of EEPROM to an Arduino Uno, so I do not know which one is correct.
                                      I need to learn this so I ended up with a Philips TV 32PFL3008D which has corrupted memory, the IC is U402, 25Q64FVSIG, I have the 3MB .bin file, how to hook up an ATMEGA328P to this memory and what code do I need?...
                                      12-03-2021, 08:33 AM
                                    • dmccul2698
                                      Pioneer DEX-P99rs "No EEProm " diagnostic code.
                                      by dmccul2698
                                      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                                      1). Understand the schematic and check the connections between the EEProm and DSP
                                      2). Check the functionality of the EEProm
                                      I don't know if this is the unit's problem but it's a place to start.
                                      I have little to no electronic experience...
                                      04-08-2024, 05:32 PM
                                    • G33RT
                                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                      by G33RT
                                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                      It does power up when pressing the power button.
                                      I already try the power button while plugin the plug with no result.
                                      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                      Could this be an PSU or eMMC issue ?
                                      07-19-2025, 03:43 AM
