Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Originally posted by srdi
    The TV does not turn on, there is no standby mode! SAMSUNG UE40MU6402
    Try.
  • srdi
    replied
  • zaratustrax
    commented on 's reply
    It was native from my tv
  • lotas
    replied
    Initially, you posted a dump from T-con IC1603 25Q80, was it native to this TV or did you already record someone else’s dump into it?
  • zaratustrax
    replied
    First at all Thanks for taking the time and check my file.
    As you said the problem is some where else. I was looking for and I discovered that the problem is on the panel side.
    I made a trick, I dissabled the Tcon protection which detetcs if the panel is connected to the Main board. So I could discovered where the problem was. And it is on the left side.
    This tv has two boards in which are Soldered the cofs. So we have a 'board-cof' left and right. And also each one is divided in two board connected through a Coffee color flex.
    I cheked this part and I couldnt find any Short or low resistente, I also try to dissabled the board in which the problem is cutting the ckv lines and covering with tape the voltages lines.
    At this point I am stuck. I am wondering if the problem are the cofs or this side of the panel is broken or something.
    Could you please tell me another way to 'turn off' or dissable this part of the panel in which the problem is?
    Again, Thanks a lot for your help
  • lotas
    replied
    Originally posted by zaratustrax
    Thanks a lot for your reply.
    I made a terrible mistake. You are right, the ic is different. And I could find the correct one.
    I attached the file, please clean my bin archive.
    Thanks again for your help and guidence
    Your dump is fine, working, so the problem is somewhere else, maybe the panel.
  • zaratustrax
    replied
  • lotas
    replied
    Hi everybody.
    I have a similar problem with my Samsung Un55mu6300.
    When I plug the cable the leds turn on and off. If I disconect the Mainboard the leds keep on.
    I was trying to fix and I already programed the bios chip using the programmer tl866ii, but no luck.
    Browsing a lot I found this post and I beg you to clear my bin file please.
    In addition I want to point that my file is 1024 kbytes Long, but to my surprise the files that the People have uploaded in this topic is half the size. I thought that maybe the chip was touch but ir wasnt. The solder points were old as the other in the board.
    If you please clear my file I am going to try the options as describe in post # 4
    Thanks in advance for your help
    You posted a dump from T-Con, it is responsible for the panel settings - this chip is IC1603 25Q80 (1024k), but you need IC1604 25Q40 (512k) it is responsible for the standby mode, if you saved the dump from 25Q80, put it back and post it from 25Q40!​
  • zaratustrax
    replied
    Hi everybody.
    replied
    Re: Samsung UN55MU6103F IC1604 dump
    Right right, I hate regurgitating shit over and over again too, our dear friend Budm would put those things he found he had to keep going over, in his signature, great idea, then he could just say look at #3 below, like pictures, that's going in mine, SOO tired of typing that shit out.
  • lotas
    replied
    Got this mini black ch341a, the software for it doesn't seem to be clickable but the rest do, do I need to pick a different one? : https://ch341aprogrammersoftware.com/
    I have posted software for CH341A many times, at least here https://www.badcaps.net/forum/showpo...81&postcount=8
    replied
    Wonder is that their official site or is it some fraud site?
    replied
  • lotas
    replied
    Quick question, can I program 25Q32FVSIG with CH341A?
    Yes.
    replied
  • giogipala
    replied
    could it be the spi t-con file?
    can I write another file?
  • lotas
    replied
    Originally posted by giogipala
    hi, I have a tvUE55MU6500U main BN41-02568B BN94-12394N the screen remains black and the TV restarts if I disconnect the panel flats the TV works, with a new main the TV can be seen well so the panel is ok.
    I tried to modify the original file with the procedure described with AsProgrammer_2.1.0.13_fix but the TV still doesn't start, maybe I made a mistake?
    This dump is working for you, the problem is different.
  • giogipala
    replied
  • cortador
    replied
    Yes, it's clear, I know, I'm only uploading it for any member who needs it, it's from a board that's working and that prevented my TV from working
  • lotas
    replied
    Originally posted by cortador
    This is the dump of the eprom of the samsung that did not work
    This is not the dump you posted, this dump is W25Q80DV (IC1603) - T-CON, but W25Q40CL (IC1604) is needed!
    09-07-2024, 05:50 AM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • jeangonbay
    Samsung UE43MU6105K IC1604 dump needed - TV don't start
    by jeangonbay
    Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
    The model of my TV is UE43MU6105K
    Main Board: BN41-02568B
    BN94-12007Y
    Could you help me to repair the dump please. Thank you.
    02-16-2024, 05:46 AM
