Samsung LN52A550 with HDMI issues
  • BretCraytor
    • Apr 2021
    • 11
    This Samsung TV, does fine with no input connected, but when I place my fire stick in the HDMI, it works briefly then starts making a screaching noise and the screen messes up with vertical lines. sometimes when this happens, it will start power cycling, going thru POST, and still screach and have scrambled picture.
    I replaced a bad cap on SMPS board, but the best I can tell, the Power board is with right voltages. Can someone lead me to where I need to look next? main board? Surely seems like it may be the input selector or something, but I don't know what chips that might be on. I have tried to find schematics/parts list, but no joy.
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Re: Samsung LN52A550 with HDMI issues
    Tell us more about your input.
    1) Does this happen with just the firestick or any other HDMI source (DVD player, game console, etc)?
    2) Does this happen a particular HDMI port or all 3?
    3) Are you powering the Firestick separately (with its own mini-usb cable connected to its own 5v / 1amp+ charger) or are you using the TV's USB port next to HDMI #3)?
    • diif
      • Feb 2014
      • 6978
      • England
      Photos are always good so we can we can see what we are working on.
        • 12192
        • U.S.
        Is it only acting up on hdmi, how about if you try an antenna for local channels?
        • diif
          • Feb 2014
          • 6978
          • England
          I suspect a faulty cap on the mainboard.
          • BretCraytor
            • Apr 2021
            • 11
            Happens on all three ports, power supply separate from tv for the firestick and the NVR for my security system which does the same thing. I don't game, so no gaming console to try, and I am rural enough that nearly impossible to get a 'local station'. if it is a bad cap, how do you find it on a SMD type board, and almost impossible to test. Local channel just static, and doesnt do it. I will try to capture some photos....thanks for all suggestions and help. I hope this further input of answers may help you help me!
            • BretCraytor
              • Apr 2021
              • 11
              oh, and it happens with a cable box on all three HDMI ports when I had one!
                • 12192
                • U.S.
                and you verified the firestick and hdmi cable on a different tv?
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  They are fine nomoresonys, it's an issue with a cap on the mainboard.
                  • KYBOSH
                    • Oct 2011
                    • 581
                    • Unknown
                    Cap as opposed to HDMI chip?
                      • 12192
                      • U.S.
                      you seem pretty sure, so help him prove it.
                      • lotas
                        • Jan 2016
                        • 4599
                        • Russia
                        First, try to update the software to the latest version (ver 1006.1 13.37 MB Sep 10. 2008), if it is not yet installed, then do a factory reset through the service menu.
                        https://www.samsung.com/ca/support/m...XZC/#downloads
                        • BretCraytor
                          • Apr 2021
                          • 11
                          Firestick fine on two other televisions. So how do you find a bad smd cap? And if I find one, how do i find the right value for replacement. I have tried several different places looking for schematics on the BN97-01985K main board, or even a parts list with the values. Ugh. Sigh.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            It's unlikely you will find schematics or parts lists. There is a reason we ask for photos. https://www.badcaps.net/forum/showthread.php?t=39740
                            • BretCraytor
                              • Apr 2021
                              • 11
                              Okay, I have the latest firmware already installed, but went through the process of checking down to the update level. Here are some pics after the factory reset was done.
                              the first one is showing air/cable input, the next I put in the firestick and went to HDMI 1, which shows the Fire TV logo, and then, before the profile screen can display, it goes to the chaos screen.
                                • 12192
                                • U.S.
                                ok, if i recall its a mainboard issue, you can do some simple tests, you will need to take the back off.
                                  • 12192
                                  • U.S.
                                  prolly have to forget about schematic, we'll try to talk you thru it.
                                    • 12192
                                    • U.S.
                                    what are all the alpha numeric digits on the white sticker on the mainboard, top row?
                                      • 12192
                                      • U.S.
                                      first look it over for anything obvious, next, easy test, find the 8 pin/leg IC and heat it for a couple minutes with a hairdryer, then test the tv, don't wait for it to cool down, test it while its still hot.
                                      • BretCraytor
                                        • Apr 2021
                                        • 11
                                        two stickers on the board, so Included a photo.
                                          09-06-2024, 06:20 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        • grimacelord
                                          Samsung UN50MU6070FXZA - HDMI Ports Not Working
                                          by grimacelord
                                          Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
                                          I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
                                          Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
                                          Since the HDMI controller appears...
                                          11-03-2021, 03:10 PM
                                        • Servicem4
                                          Pioneer lx 701 hdmi issues
                                          by Servicem4
                                          My receiver pioneer LX 701 doesn't work anymore correctly The history:
                                          6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
                                          Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
                                          The rest of the receiver works, I used spdif for sound input.
                                          I now opened the receiver and hoped to find a blown fuse but all look good.
                                          Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
                                          Image 20250527-204839 hosted in ImgBB
                                          05-27-2025, 01:13 PM
                                        • Kambi13
                                          Samsung LF22T350FHRXEN wont work with HDMI port. Either cant get 1980x1080p resolution, or I get out of range message
                                          by Kambi13
                                          Hi all I have 2 Samsung LF22T350FHRXEN, working in a dual screen setup. Out of the blue one of them now wont display full resolution trough HDMI port, Either get out of range message or it will be stuck at 1024x768px. Tried reseting the screen, tested different HDMI Cables but with no luck.
                                          Need some advice
                                          Best Regards
                                          04-30-2024, 11:35 AM
