Samsung 75"QN75Qn90AAFXZA Horizontal line
  • yankys
    yanky
    • Feb 2012
    • 139
    Hi, everyone this 75" has horizontal lines and jittering I did a visual check on the ribbon cables and reset them still same results it will work for awhile then reboot and play again, could it be a main board given that the t-con and main board are one.
    • 12269
    • U.S.
    Re: Samsung 75"QN75Qn90AAFXZA Horizontal line
    prolly like this, are your symptoms similar? if so maybe see if you can do the same tests, the models are not the same, so there may be some differences: https://www.youtube.com/watch?v=XCJAx92JwPs
    • yankys
      yanky
      • Feb 2012
      • 139
      I did that in the video, and no change, both sides remain the same no matter which cable you unhook.
        • 12269
        • U.S.
        ok, thats a good test, it may just be the mainboard thats the issue then.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          there's nothing you can do
          • yankys
            yanky
            • Feb 2012
            • 139
            Hi, everyone just wanted add that I timed the reboot and it’s 3 minutes each time could this be a mainboard issue tv plays like normal even after the reboot.
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
              09-07-2024, 05:50 AM
            • kotel studios
              Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
              by kotel studios
              Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
              In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
              08-06-2025, 02:07 AM
              09-06-2024, 11:40 PM
