LG OLed Main Board Swap Upgrade Compatibility
+ More Options
Posts
  • Zac827
    • Feb 2025
    • 6
    Also mine is definitely not screen burn as it did not occur with the last board. My next option is to purchase a c9 board as its much closer in age and model to my c8. Trying to get the 120hz feature, which I did get with this bx board, but the pixelated colours are almost unbearable in some scenes. Did you ever try the c9 board like you stated you were going to?
    • cheebster
      • May 2008
      • 370
      Yep, the cloud issue cleared itself after using the tv a few minutes, did you try that ?
      Did you leave the original Tcon on the panel ?
      • Zac827
        • Feb 2025
        • 6
        yes, I only have the original tcon. I have tried updating the software so they can align, I have used the TV for several hours and it is still happening. it seems its not present when using the VIVID picture mode, I have tried adjusting all settings in other modes to see if its something specific, to no avail. I rather not use vivid picture mode as I am wanting to use it for gaming. any ideas?
        • Zac827
          • Feb 2025
          • 6
          I wonder if its because you used the "in_stop" on a service remote. apparently that resets the panel itself. thats the only thing I have not tried as I don't have a service remote.
          • Diah
            • Feb 2013
            • 6357
            call in_start service menu.. and show what do you have under OLED
            • Zac827
              • Feb 2025
              • 6
              • Diah
                • Feb 2013
                • 6357
                here are the issue.
                Panel Matching NULL ..... it should be OK
                Source PCBA PID NULL here should 12 serial listed
                T-CON PCBA PID NULL here should the same above serial
                TRY;
                downgrade the firmware first... then updated to the last hopefully will listed the missing .. or via IN_STOP
                • Zac827
                  • Feb 2025
                  • 6
                  here are the issue.
                  TRY;
                  How do I downgrade? I dd already update the software, but from what I'm reading online LG put a stop to software downgrade.
                  • Diah
                    • Feb 2013
                    • 6357
                    go back to read post #8
                    • Dani_2024
                      by Dani_2024
                      10-28-2024, 05:06 PM
                    • jb_Bak
                      by jb_Bak
                      CN6401
                      Pin 01 NC
                      Pin 02 NC
                      Pin 03 "BL_ON": 0V
                      Pin 04 "N/C"
                      Pin 05 "STBY 3.3V": 3.5V
                      Pin 06 "GND": N/C
                      Pin 07 "AC_OFF"...
                      09-27-2021, 04:52 PM
                    • JDC
                      by JDC
                      ONN 100012588
                      Long answer:
                      07-15-2022, 07:39 AM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • cheeky2
                      by cheeky2
                      05-25-2024, 03:27 AM
