Samsung QLED QN55Q80RAFXZA - No backlights
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4463
    • Italy - Milan
    Re: Samsung QLED QN55Q80RAFXZA - No backlights
    why do you want to do this? Now it's important to ascertain what's wrong except power board, why don't you follow the advices? When a fuse blowns almost surely there's a short at valley so don't worry about it, leave it to background..
    • nomoresonys
      • 12276
      • U.S.
      simple dim bulb tester to detect shorts and keep from blowing shit up, demonstration around 7:40: https://www.youtube.com/watch?v=wRFRwOnLsZI
      • DennisKal
        • Jan 2023
        • 18
        Davi.p,
        CNM801
        Pin 5: VAMP = 18.1V
        Pin 7: VAMP = 18.1V
        Pin 11: A13V = 13.04V
        Pin 13: A13V = 13.04V
        Pin 17: A13V = 13.04V
        Pin 16: Power On/Off = 3.3V
        • DennisKal
          • Jan 2023
          • 18
          Davi.p, I don't think B13V is connected to QM884. The bottom leg is A13V but neither the top leg or middle leg is connected to B13V.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4463
            • Italy - Milan
            i'm almost sure of what i wrote, and also i'm 100% sure B13v is switched somewhere from A13v and i see only QM884 can do it, so next step is yours.. c'mon..
            • DennisKal
              • Jan 2023
              • 18
              Davi.p, I checked it from the top side with a digital voltmeter. All three pins were accessible. None showed connectivity to B13V
              • DennisKal
                • Jan 2023
                • 18
                Davi.p,
                Since I have easy access to the back side of original dead power board, I checked the trace for B13V. You are right that it goes to the center leg of QM884. I double checked again the new board that we have been debugging on the top side and it shows no connection. I don't want to peel up the glue on the bottom side sine I plan to return it as defective to hopefully get another board that works.
                Will post an update after that.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4463
                  • Italy - Milan
                  #28
                  I was only suggesting you to try and make a small solder jumper on source-drain if is a mosfet or collector-emitter if a bjt, so you can right now test the entire tv.. maybe only QM884 is out of order.., i don't think somebody notice it..
                  • DennisKal
                    • Jan 2023
                    • 18
                    I received a replacement power board from TVPartsToday and very pleased that the TV immediately worked. I really appreciate the insight and help on the debug of what was happening. You guys found the issue quickly which enabled me to request the replacement.
                    Next time I’ll start here!
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Glad to hear you got it working. Thanks for updating everyone. Also just curious if tvpartstoday made you pay for shipping on the return or how they handled it.
                      There is another thread on here discussing this. So curious what your experience was
                      • DennisKal
                        • Jan 2023
                        • 18
                        tvpartstoday dispatched the replacement parts immediately after I submitted the form on their website. I had 5 days to determine if the replacements worked and then they would tell me the next step regarding returning the bad parts. They shipped them fast and I received them in 2 days. After I let them know it was successful they instructed me to just recycle the parts myself… no need to send them back.
                        On the whole, I am satisfied with my experience with them. Sure I would have liked to get working parts the first time but I recognize that we are working with parts that are not new from the factory.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4463
                          • Italy - Milan
                          #32
                          The replacement boards are new only when them comes from smashed tv by the shops shipments, anyway i suggest you to test qm884 and if found to be bad replace it so you have a second working board, if qm884 marks good at diode mode of tester then something bad around the gate
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • ohren
                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                            by ohren
                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                            The models launched in 2018 and 2019 respectively....
                            09-08-2023, 05:24 PM
                          • C152Heavy
                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                            by C152Heavy
                            Summary for TL-DR readers:
                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                            • Have read ALL applicable threads
                            • C1818 and CP820 replaced as low hanging fruit
                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                            • VCC pin (18) of PFC...
                            01-11-2023, 02:53 PM
                            09-07-2024, 05:50 AM
