Need hp laserjet m28w firmware
  • ziko07
    • Jun 2021
    • 102
    • Somewhere
    Anyone has this firmware?
    it stuck on update....
    Tnx
  • aboumohamed
    • Dec 2018
    • 258
    • algeria
    try. same logic card
    • Faluky
      firmware for Marantz SR5008 stuck in update loop
      by Faluky
      After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
      Best regards.
      Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
      01-17-2023, 04:33 AM
    • Meraxes
      Ps4 Slim firmware update stuck on 53%
      by Meraxes
      I have a Ps4 Slim, it works perfectly, I wanted to update to firmware v 10.1 and now it remains stuck at 53%, before it had version 6.50
      Hdd is ok, it is tested with hdtune pro
      The Blu-ray worked perfectly before the update
      I tried several USB flash drives, no change
      The wifi module was changed does the same
      Can someone help me ? can the southbridge have problems?
      03-07-2023, 09:37 AM
    • Daniel Larsson
      Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
      by Daniel Larsson
      My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
      I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
      During these seconds the function button is not working...
      08-13-2025, 10:29 AM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • mferna14
      Apple 820-01958-A logic board stuck on 5V .19amp
      by mferna14
      Hi friends, working on a MacBook Air A2179 logic board 820-01958-A logic board. It's just stuck on 5V .19amp on one USB-port & then when I use to the other port it's also stuck on 5V .19amp but on this port it resets after few secs & start over with the same said voltage. I assumed that one of the CD3217B12s is defective, & replaced both with known good ICs. The status & result remains the same. I checked for shorts or liquid spill, all clear. On F8400 there is 12v present, but no 5V or 3.3 volts. There are LDO voltages on the both CDs 3.2v & 1.5V. Kindly if someone can help...
      02-21-2025, 03:42 PM
