Flipping 120mm fan in ATX PSU?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    I'm curious if anyone has any input on how bad it is for the power supply to flip the fan? My secondary system that I honestly rarely use has a 500W CWT 80Plus Bronze PSU that came out of some low-mid range prebuilt desktop at some point.
    Anyway, I replaced the stock Yate Loon 120mm fan for a Cooler Master RGB fan, but I decided to install it backwards so that it pushes air the same direction as the GPU fans right above it, as I have the PSU installed with the fan facing up. The GPU I'm going to end up putting in here is an XFX RX 6600 8GB, so it's not a super power intensive card.
    Long story short, is this going to lead to the actual components inside the power supply (capacitors, etc) running hotter since the airflow pattern is different, is it going to lead to better cooling since it's sucking in cold air vs warm air from inside the case, or is it going to make pretty much no difference whatsoever? I did retain the little plastic cover they had on the bottom of the fan that blocks off about 1/4 of the fan closest to the outside of the PC.
    • 31068
    Re: Flipping 120mm fan in ATX PSU?
    in your case you have no choice,
    either you keep the flow from gpu to outside via the psu, or you have them blowing at each other and reducing the flow and causing turbulance that creates noise.
    i would bypass any fanspeed crap though - have it sucking the air out of the case at top speed.
    • CapLeaker
      Leaking Member
      • 8196
      I did the same thing a few times in airflow restricted cases to maximize airflow vs fans pushing each other. Never had a problem.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        The fan curve is pretty aggressive as I’m using a 115W CPU with a 92mm generic eBay tower cooler and since my motherboard only has a single fan header I’m using a splitter so the PSU fan ramps up with CPU.
        I’m honestly not sure what you mean about me not having a choice. I could simply have left it alone and have the fans fight each other like most builds. My GPU does have the through section for air to flow on the part of the cooler after the PCB so I think it will work nicely. Cool air comes in through the PSU, the GPU takes it and blows it upward, the CPU fan catches it, and it goes out the back and top of the case. I don’t have any case fans, really no need in this case, no pun intended.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Good to know. I don’t anticipate any issues just overthinking stuff like always.
          My hope and dream is that under light gaming load the GPU fans will stay off as this card as the idle fan-stop function and I rather not have the fans starting and stopping all the time.
            • 31068
            i would be carefull, some games idle the cpu and use the gpu for the heavy processing.
            if your psu controls fan speed based on air temperature then o.k. but if it's based on heatsink temperature or output load i would bypass it.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Alright, so I compromised and reinstalled the original fan that the PSU controls however it wants, but I did put it in flipped so the airflow pattern is how I want it. And I put in a different CPU/mobo combo and put my other 120mm fan at the top of the case so now it's perfectly bottom to top
                • 31068
                assisted convection cooling
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Ha, yes!
                  • SluggerB
                    Cooling experts wanted.... (with pictures)
                    by SluggerB
                    So if you have been following my urine odor saga with my new PC, I believe I finally found out what is happening, my Northbridge heatsink is getting quite toasty, and other people online with my motherboard say the VRM's get hot as well. That may be the source of the odor I am smelling.
                    Current setup
                    The case has 3 fan openings, a 120mm front, a 120mm side, and a 92mm rear. Currently the only fan installed is the 120mm front. The CPU cooler has a side mounted 92mm fan on it (and that cooler is very cool, CPU temps are great). The only exhaust is from the PSU
                    04-12-2022, 07:28 AM
                  • evilkitty
                    ZD-915 not sucking (not clogged)
                    by evilkitty
                    I have a ZD-915 de-soldering gun, i am not getting any suction, there is no clog and i get next to no suction at the nozzle, i have suction at the back of the gun
                    i was trying to find the issue when i noticed this part does not fit snug around the tip going to the top
                    my nozzle has a diameter of 0.1" and my rubber part linked below has a diameter of 0.155"
                    https://eleshop.eu/rubber-sealing-ring-zd-915.html
                    Am i missing a part or has the rubber melted?
                    07-06-2024, 04:09 PM
                  • Jane
                    Quick 861DW What temperature and airflow to use
                    by Jane
                    Guys,
                    what temperature and airflow do you use when desoldering/soldering parts on graphics cards?
                    I use Quick 861DW station.
                    Is it necessary to use preheater for also for small ICs or for GPU only?
                    Thanks for replies
                    04-15-2022, 01:45 AM
                  • piernov
                    Core 2 "gaming" build with SLI
                    by piernov
                    My turn to post a build I guess, wasted way too much time on this one…
                    First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
                    Everything done with random parts I had lying around.
                    Specs :
                    • CPU: Core 2 Quad Q9450
                    • RAM: 2x2GB KHX6400D2K2
                    • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
                    • MB: P5N-E SLI
                    • PSU: Antec Basiq Power 550 Plus
                    • HDD: Hitachi Ultrastar A7K2000 1TB
                    • ODDs: DVD ROM, DVD RW
                    • Case: not sure
                    Cooling:
                    • 92mm rear fan
                    • 120mm front fan
                    • Additional heatsink on southbridge
                    05-20-2023, 11:38 AM
                  • paparazzo79
                    flipping adapter on external HDD got it "alive"
                    by paparazzo79
                    Hi guys.
                    The adapter for my external WD My Book was left on the wall socket (extender).
                    I connected the USB cable to the laptop and nothing the disk was dead (I couldn't hear motors).
                    Gosh I got scared that my HDD died on me...I tried other PCs same issue.
                    Then I unpluged the adapter from wall socket(extender) and just flipped it other direction.Now it works.
                    Now I want to know,curiosity killed me,why does it matter in this case,how to adapter is plugged in.
                    01-17-2022, 11:59 AM
