Cooling experts wanted.... (with pictures)
  • SluggerB
    • Aug 2020
    • 747
    • US
    So if you have been following my urine odor saga with my new PC, I believe I finally found out what is happening, my Northbridge heatsink is getting quite toasty, and other people online with my motherboard say the VRM's get hot as well. That may be the source of the odor I am smelling.
    Current setup
    The case has 3 fan openings, a 120mm front, a 120mm side, and a 92mm rear. Currently the only fan installed is the 120mm front. The CPU cooler has a side mounted 92mm fan on it (and that cooler is very cool, CPU temps are great). The only exhaust is from the PSU
    I came up with 2 options for cooling the Northbridge/VRM's:
    Option 1
    The stock case side opening is near the Northbridge, and the 92mm is by the VRM's. I could install fans in those openings and see if that amount of airflow solves the issues.
    Option 2
    I could rig up a few small 20mm-40mm fans, I could screw one directly onto the Northbridge heatsink, and I could fabricate some sort of bracket to hold 1 or 2 of them over the VRMs
    Currently there's not a lot of airflow THROUGH the case, which #1 would address, but that would not have air blowing directly on the components I want to cool, which #2 would address. I could do both but then I need to run fan header splitters and wire management origami.
    Suggestions on which path to take? I am leaning towards getting 2 new, high quality 120mm fans and a high quality 92mm fan and going with option 1 (as well as replacing the existing stock 120mm in the front), and then if that doesn't work adding a small fan to the Northbridge heatsink directly since I think that is the source of th odor (it is the hottest thing by touch in the case)
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Cooling experts wanted.... (with pictures)
    I'd go with a hybrid approach. Go with #2, but also do the case fan upgrades.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • TMTGTR
      • May 2022
      • 28
      IMHO I believe this is a good course. I personally go "overboard" with fans. But I have 9 PC all quite old (6 XP + 2 98/ME + 1 Win7). They all work fine except one I need to Recap.
      That said, all of my fans are exhaust. I never use intake. I have a friend who was US Navy guided missile system technician (1960's - 70's) He advised me on that. I also read a PDF back in the 90's (I think ASUS) that said exhaust fans in the same system Vs. intake fans resulted in a 1.xx degree difference with exhaust being cooler.
      I never did an actual A/B test myself. Just thought I'd share that. Good Luck!
        • 31289
        use baffles and ducting to direct the air where you need it
        incidentally, i go the other way.
        BIG intake fans to create a positive pressure inside the case.
        then if you put intake filters on the fans the case stays clean.
        • Ace Perception
          Samsung R530 Bremen motherboard cooling
          by Ace Perception
          I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
          I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
          So I went in pursuit of...
          07-21-2020, 03:05 PM
        • piernov
          Core 2 "gaming" build with SLI
          by piernov
          My turn to post a build I guess, wasted way too much time on this one…
          First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
          Everything done with random parts I had lying around.
          Specs :
          • CPU: Core 2 Quad Q9450
          • RAM: 2x2GB KHX6400D2K2
          • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
          • MB: P5N-E SLI
          • PSU: Antec Basiq Power 550 Plus
          • HDD: Hitachi Ultrastar A7K2000 1TB
          • ODDs: DVD ROM, DVD RW
          • Case: not sure
          Cooling:
          • 92mm rear fan
          • 120mm front fan
          • Additional heatsink on southbridge
          05-20-2023, 11:38 AM
        • Hondaman
          Liquid cooling?
          by Hondaman
          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
          (After previous generation hardware [Gigabyte] didn't...
          05-08-2025, 09:37 PM
        • kotel studios
          Asrock 970 PRO3 - missing 1.1V on NorthBridge
          by kotel studios
          Recently I got this Asrock 970 PRO3 board from scrap. It had a few missing caps under the NB which I've replaced. Sadly, one of them went short (NC597 from boardview file). I did replace it and there doesn't seem to be any shorts left, but the board is not executing POST nor beep codes. I once got it to POST after I was slightly bending it, but that was only once. I tried to redo the same steps but to no avail. All caps on the backside of NB have 22-ish ohms.
          I have traced the problem to an dead Northbridge VRM. There's no voltage on Phase (pin 8), FB (pin 6), UGATE...
          08-02-2025, 02:34 AM
        • mikey5791
          Help repair Panasonic fridge not cooling
          by mikey5791
          Hi all forum members,
          Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
          After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
          07-16-2025, 02:01 AM
