Digital power factor correction
Mann-Made Global Warming.
- Dr Seuss
Re: Digital power factor correction
hence why i would like to go into politics someday... since there are so many bum politicains out there, i think i could do better and i hope other would think so too. not that anybody here would vote for me... most around here seem to be extremely conservative while i tend to be liberal on a lot of things (not all).
as for apfc... i think there will be bigger things go through before they get to that. like car emissions and wind power.sigpic
(Insert witty quote here)Comment
Wind [and solar] power isn't going to do sh*t as an industry because without gov't subsidies it isn't 'efficient' at making money for investors.
The gov't is broke. - Subsidies are going away.
Obama's solution to make wind power 'efficient' at making money for investors is to tax the snot out of oil to make it more expensive than wind power alternatives.
- That's the gist of his "incentive plan" for wind and solar power.
That plan will actually work if he can get it through congress but gas and electricity prices will double or more in the process.
.Mann-Made Global Warming.
- Dr Seuss
PCBONEZ; that is interesting
I'll take Denmark as an example, one of our neigthbours here in Scandinavia
They produce 18% of their own electricity though wind power, that is an amazingly high number (highest in the world actually)
And they are very very proud of it
Untill someone like me comes up and asks where the other 82% comes from; the answer is coal plants in Germany!
Atleast this new uber PFC might allow them to use smaller gauge cabling to Germany
Haha, just kidding with you"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Back to the original post.
DigiKey, Mouser, Avnet have them. Avnet's cheapest.
Datasheets attached.
Cheers!
Toastveritas odium paritComment
You can do an universal-input PSU WITHOUT needing APFC, it's just cheaper to do it like that. But anyway, i can agree with APFC being semi-useless in average (500 watt range) computer power supplies, but when you're talking kilowatts it starts to count.
When you're trying to squeeze 4kW out of a 230v circuit, a power supply with APFC won't trip a 20A breaker. A power supply without, will.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
I have a ATNG AP-500X that has universal input without APFC. Kind of funny as the unit is silkscreened to have APFC.Comment
- Dr Seuss
That chip is an itty bitty thing. Need to order a SOIC to DIP adapter just so you can get your hands on it! Digikey sells Aries adapter p/n 08-350000-10.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Cool I didn't know they made SOIC to DIP adapters not good for the final product on a PCB of course. But very good for prototyping it on a breadboard.Elements of the past and the future combining to make something not quite as good as either.Comment
I have the chip already. So small I darn near didn't find it in the envelope. So I have ordered one of those adapters. That way I can solder the chip to the adapter, and plug the adapter into an 8 pin dip socket on my breadboard.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Toasty is right......another everell project has been launched. I am using a discarded Bestec ATX-250 12Z to convert from what it is to one having APFC using this new CS1500 chip.
So far I have removed the two main capacitors and replaced with the one main capacitor. I have wound a booster coil and mounted it. And I have added the big .47 Mfd filter capacitor across the bridge rectifier. Picture attached.
Next is some "cut and paste" of circuit traces on the bottom of the board. Then I will prototype the breadboard using the new CS1500 chip.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
I was a bit concerned as to how well the A6351 chip would perform the 5vsb function when the startup voltage across the main capacitor is only 160 volts rather than the 320 volts used in the usual doubler circuit. So today I did the basic wiring to hook up bridge rectifier, main capacitor, and 5vsb circuit. On power up, the main capacitor charged to 162 volts. The A6351 came up just fine giving 4.98 volts on the 5vsb line, and powering the supervisory chip such that the "Power Good" LED came on as expected. The feedback circuit voltage measured 14 volts, plenty to power the main pwm chip, and hopefully the new APFC chip also. So this first test before wiring the APFC components was a success.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Congrats!Mann-Made Global Warming.
- Dr Seuss
This evening I put it all together and fired it up. The output voltage using the suggested feedback resistor values came to 425 volts. A little higher than expected. I will do some further experimentation to see if I can reduce that voltage to something more like about 385 volts.
The dark picture shows the psu tester LEDs lit while operating. The three green ones are the three rails, 3.3 volts, 5 volts, and 12 volts. The amber one is the 5vsb. the red one is the power good indicator.
The new chip may function great for better power factor correction, but the BIG problem with this circuit....and ALL APFC circuits I have worked on so far......the booster coil gets super hot. That means either a burn up over time, or a shorted coil at some point in the future.
Since so few technicians are willing to take a power supply apart and determine WHY it failed, I predict that we are going to be seeing lots of power supplies fail because of the heat generated in the booster coil of the APFC circuit.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)Comment
Assuming...7 Photos -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 02:15 PM
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
- Loading...
