Help saving this power controller for FURNACE
  • imcool
    • Apr 2016
    • 18
    hello,
    I have an old furnace in house and this is its working control module.
    How can I collect information/date/readings/measurements from this working module so in case if something happens to this working module I can cross check from the information noted down and find broken component easily.
    Should I take diode mode measurements of all the soldered pins on the board?
    Any other ideas?
    I am not too good electronics troubleshooting
    thankyou
    • 31094
    Re: Help saving this power controller for FURNACE
    dont bother with readings, other than maybe the coil - but i doubt you will get any.
    a lot of ignition coils also contain other parts under the resin.
    what may be usefull if it blows will be a record of all the resistor colour-codes
    because if one burns up you wont be able to see the colours afterwards.
    also consider either replacing the fuse with a ceramic one or puting sleeving over the original.
    if the board shorts out it could shatter the glass fuse and make a real mess!
    • imcool
      • Apr 2016
      • 18
      Thanks,
      I was thinking to go on green side of the board and use diode mode measurements on each of soldered point on green side.
      • master3112
        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
        by master3112
        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
        10-29-2024, 09:32 PM
      • ronnygracias
        Help with freemotion incline trainer with controller comm error
        by ronnygracias
        The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
        11-04-2024, 01:32 PM
        Tankless hot water heater controller board not powering up when power is applied
        I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
        I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
        However I would like to know if I could figure what happened to this controller board if possible
        Tomorrow I will take some better pictures of both side of both boards
        The...
        12-09-2022, 09:14 PM
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
        Modifing a Battery Spot Welder because of Controller Issues
        I keep having the same exact issue with these battery spot welder controller boards
        They either do one of two things
        One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
        Or
        The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
        This...
        10-12-2019, 08:51 AM
