Xerox WorkCentre P220
  • smason
    • 1652
    Here's something different. A Xerox multifuntion printer/copier/fax.
    Model P220 a.k.a. Phaser 3200 a.k.a. Samsung somemodelerother
    THis is from a field office, and I was told that the original symptom was it stayed at "warming up" so I suspected a fuser problem, then it just wouldn't power on, makes a ticking sound.
    I'll probably replace it, but told them to send it to me anyway.
    Smells like a power supply issue to me, LCD doesn't come on, speaker makes a faint ticking sound, and the fan(s) cycle on/off in time with the ticking.
    Disassembling finds the power supply with 1 bloated cap. a 1500uf @ 10v
    It measures 100uf and 5ohms esr out of circuit.
    Replaced it, checked a few others, and the supply output on the bench is 5v and 24v as it should be, but not under any great load....
    Will pop it back in tomorrow and see.
    I'm not 100% sure it's not a problem with a shorted component in another board, but the rest are buried deep inside this thing, so hoping not.
  • smason
    • 1652
    Re: Xerox WorkCentre P220
    It's alive!!
    I'm actually pretty surprised, I really thought it was something else loading down the supply, but I re-installed the PS, fired it up, and it tried to send a fax that was in non volatile memory.
    It copies, and prints! Another $0.33 repair. Hmm guess I'd better fill out an expense report.
    P.S. the Samsung equivalent model is SCX-4521 if anyone cares.
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Nice work!
      Probably a good idea to replace the rest of the caps from the same brand on the PSU board, though (except the big 400v one).
      Lol. It's probably $0.34 if you count the price of the paper and ink used to print that expense report .
      • smason
        • 1652
        I was going to replace the others, but didn't have them. They checked out ok, will add them to my next order of caps.
        They were Samxons, if anyone cares....
