Printed board polarity correct? How can I tell?
  • kiddznet
    • Jul 2010
    • 176
    Can somebody help which is the negative connection on this Speed 580W PSU?
    Ive got two new 470uf 250v caps to try and as I never took em off wanna be sure
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Printed board polarity correct? How can I tell?
    The shaded or black area is negative (short lead).
    --- begin sig file ---
    --- end sig file ---
    • kiddznet
      • Jul 2010
      • 176
      Thank you Sir! up and running. I had to drill another connecter hole in the board to alow the two fat Rubycons in
      PS. Don't look to close at the bridge I put in the blown fuse!
      • c_hegge
        • Sep 2009
        • 5219
        Nice, but it still could use a few more things.
        1. Replace the fuse! NEVER run a PSU with a jumped fuse.
        2. Replace the the rest of the caps with good quality ones.
        3. Replace the 4 diodes near the primary caps with a rectifier.
        4. A beefier main transformer.
        • kiddznet
          • Jul 2010
          • 176
          I looked at the rest of the caps, man you should see the jumble that is the soldering on the bottom of the board!
          If found this baby in the rubbish bin, it will be a good supply for testing all the equipment I find...er... in the rubbish bin!
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            With that transformer it is limited at ~250w.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Looks like a diablotek DA series.
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • sotodefonk
                Help finding the correct model of a T-Con board on my Hitachi TV
                by sotodefonk
                Hi, I have a Hitachi tv model L47V651, there is no image, but sound and backlights turn on, so I believe the issue is the tcon board.
                I opened the tv to access the board and took the shared pictures of the T-Con board.
                I saw a video from shopjimmy on how to detect the model number on tcon boards, but this doesn't have a sticker like how that video showed all boards.
                I searched the P/N number and got results with the same marking name and P/N my board has but they list other specific tv models like Vizio and Philips brand but not Hitachi.
                Inspecting...
                06-28-2024, 04:39 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
