Operation of the 5VSB system?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, I have a simple question on the operation of the 5VSB system
    Do the components running off it (chipset, NIC's, USB etc) continue to run from this rail when the system is powered on?
    I know from inspecting the power circuits of the motherboards RAM slots that there is a transistor that switches the RAM from 5VSB to 5v or 3.3v when the system resumes from standby
    But do the other circuits have this too?
    Reason I ask is that lately my cardreader and USB stick have stopped working, so I am suspecting a malfunction amongst any of the computers I use (Including people I know)
    It could of course be just a coincidence too...
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Operation of the 5VSB system?
    Bump
    Nobody knows?
    My Google skills seem to be of no help on this quest either...
    • Krankshaft
      • Jan 2007
      • 2328
      There would be an easy way to test this clip the 5vsb wire and hook a meter set to measure current across it.
      Then power the PC on and see how far it drops.
      If you have a DC current clamp you could do this less invasively.
      I would think the latch circuitry that keeps the PC on with the momentary push button switch would remain connected to the 5VSB and some wake on lan NICs run while the PC isn't powered up. Some mobos send 5VSB power to the USB ports with the PC off. Can't think of much else that uses it.
      If you're devices have stopped working check the 5V source at the USB port most mobos have a protection fuse that will blow if a device tries drawing more than 500ma.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Thanks Krankshaft, I was actually considering going the meter route, didn't want to cut a wire in the nice PSU tho, but I have one here with a non-functioning 5VSB that I might use for testing, will force me to fix the PSU too
        About the USB ports on my computer, they work fine, other devices works fine on said ports...
        It's just a cardreader and USB stick that has stopped working for no apparent reason
        But it seems I might be zeroing in on the culprit because today I was at a friends place and he too had a bad USB stick, I suspect it is a friends of his that has the culprit computer
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Ok, I fixed the PSU, it was easy
          2x 2200uF 10v bulging caps on 5VSB secondary side, replaced with 2x Rubycon 3300uF 6.3v MBZ
          (My rubies are getting kind of old so want to use up my stock, otherwise such a nice cap would have never gone into this thing )
          When the computer is soft-off it draws 1.5A from 5VSB
          When I start it this drops to 0.3A
          When I enter S3 standby mode it also draws 1.5A
          If I remove the NIC cable it draws 0.2A less in soft-off and standby, while running there is no difference...
          I tried disconnecting 5VSB when the computer was running
          I lost the VGA output and the CPU fan turned off but the system was still running, because my power meter showed 81w... The PSU fan was on aswell... (When running idle it draws 77w which seems to be correct, because 0.3A x 5v = 1.5w + the CPU fan)
          So I don't know what it uses 5VSB for while running but it seems to be something crucial
          Also I was pinging the computer from another computer over the network and it stopped replying as soon as 5VSB was gone, however the NIC LED's where still lit...
          The 5VSB was very stable after my 8 year old Rubycon caps had a little time to warm up
          It was at 4.0v first but I left it plugged in for 10 minutes and then it had risen to 4.97v
          And it keeps this voltage stable in a transient test going from running in idle to standby mode (I don't have an oscilloscope though)
          As for the original caps what are they, that S logo inside an eye?
          As for the PSU this is how it looks, not half bad actually
          Good input filtering (there is extra filtering on a small PCB behind the power receptable aswell, consisting of 2x Y caps, a Ferrite coil and an X cap)
          Also if you want to see something EXTREMELY funny look at this old post by me, of a PSU with an identical model number, but higher ratings on all the outputs...
          Last edited by Per Hansson; 05-18-2014, 09:55 AM. Reason: Offsite images uploaded due to problems with host
          • POM_MJ
            • Aug 2009
            • 228
            Those are CS caps, known crap brand.
            I recommended to replace all of them. They've much leakage when they failed then cause silicon blown out.
            one of mine => https://www.badcaps.net/forum/showpo...3&postcount=95
            | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
            | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
            | 2xWD7500AYYS | 2xHD322GJ Raid0 |
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              This is a macron power mpt-301, a very good 300watt psu.
              I have a unit like that that had bulging primary 680uF cs caps.
              https://www.badcaps.net/forum/showpo...86&postcount=3
              My psu also has a bridge rectifier of 6 A, not 4 diodes and larger 13009 primary transistors. It has mov too...
              I replaced all caps with panasonic and rubycons and the psu works like a charm.
              https://www.badcaps.net/forum/showpo...5&postcount=48
              I think Rubycon MBZ are a bit too low esr for psu.
              About the "CS" caps... http://capacitor.web.fc2.com/
              website: http://www.12kj.com/
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Thanks for your replies POM_MJ and goodpsusearch
                I will keep this as a PSU for testing only, not for usage, would it see usage I would for sure do a full recap
                Anyway I noticed for example on POM_MJ's PSU there is the 115/230v selector switch, mine omits this switch (fixed @ 230VAC)
                Also I see where the PFC coil is supposed to be placed on my PCB, CN3 in the attached photo (The selector switch cables go here to SW2 and SW1 hidden between the furthermost Y capacitor and the coil behind it, what does that coil do btw, just noise supression?)
                It will be a good test PSU "for that other thread" if I ever find a PFC coil
                Also it would be fun to try and design a safe 5VSB circuit for this PSU, which if I'm not completely off my base uses a two transistor design?
                Lastly in the other pic you can see my über safe testing environment
                • POM_MJ
                  • Aug 2009
                  • 228
                  The coil labelled MP-EE25-1 and CX,CY is transient filter to separate noise between AC line and high voltage side of the PSU.
                  to mod 5VSB circuit, see Bestec ATX250-12E up and running! by everell, he's an expert.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    I think it does, as every psu at that price range.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Yup, two transistor all right.
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        POM_MJ; thanks for the clarification
                        I had already read the 5VSB mod thread by everell, that is what has peaked my interest
                        370forlife / goodpsusearch, thanks for the confirmation
                        Btw, that transistor on the right of the 5VSB transformer, is this also part of this circuit?
                          master hoarder
                          • May 2008
                          • 12164
                          • Bulgaria
                          I also have a Macron Power mpt-301. Just recapped it about a month ago.
                          While it does seem to use a 2-transistor 5vsb design, I was not able to locate the so-called "critical cap". There are a bunch of 10uF caps on the secondary, but I don't think those are it. Perhaps it's a modified 2-transistor design? In most other 2-transistor designs I've seen, the critical cap is always on the primary side near the 5vsb transformer.
                          As for the transistor on the right of the 5vsb transformer - from what I remember, that was just part of the feedback loop for 5vsb.
                          By the way, if you're fixing this PSU, you might also want to change the loading resistors on the 3.3v and 5v rails. Mine had a 10 Ohm on 3.3v, and a 25 Ohm on 5v - that's almost 2W of heat being dissipated, and it's pretty close to the caps, too. I put the 25 Ohm on the 3.3v and a 100 Ohm (from another PSU) on the 5v.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Thanks for the input momaka, but look in the picture 370forlife posted
                            Right above the two circled transistors there sits two capacitors, right by the 5VSB transformer
                            10uF 50v, don't you think those are it?
                            Earlier I provided this link to a better resolution shot aswell:
                            https://www.badcaps.net/forum/attach...1&d=1399817566
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Do the components running off it (chipset, NIC's, USB etc) continue to run from this rail when the system is powered on?.
                              Some do and some don't.
                              Depends on the specific board too.
                              Sounds like you figured out the RAM
                              USB usually switches between +5vsb and +5v based on system state too but not all motherboards do it. [Same with PS/2 sometimes.]
                              You need a little power on USB when it's in soft-off so USB keyboard hot-keys can boot it, but once it's running they don't want all the USB loads from 6 or 8 ports piled onto +5vsb so they switch it.
                              Just about anything that is "wake-on" can be set up that way if the board designer wants to.
                              That might include power feeds to PCI slots that need to be capable of supporting a "wake-on" NIC or modem. Not sure about that one but there aren't any PCI pins devouted to +3.3vsb or +5vsb. [Maybe that jumper provides vsb to the card but I -think- I've had WOR modems and WOL NICs with no jumper connector.]
                              Mann-Made Global Warming.
                              - Dr Seuss
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                Thanks for your insight PCBONEZ
                                Actually that cable which connects the the NIC for WOL, atleast on this board it is not needed, because the NIC is indeed lit when the computer is off
                                (And it made a 0.2A difference when I unplugged it's RJ45 cable too)
                                The mobo I'm testing with is an old Socket 370 with a 1400Mhz Tualatin Celeron and a FIC FA15T mainboard
                                It does not support wake from USB, so I guess it does not have a switch for USB from 5VSB to 5v
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  FIC was pretty decent back in the P3 days.
                                  I have a couple of FIC FR33E I held onto in case I needed to test an old ISA card. Similar to your board but these are uATX.
                                  Except for four 470uF SI in not so critical places they had all MBZ as original. None of the SI were bad but I replaced them anyway.
                                  Contrary to what FIC says they fully support 1.4GHz P3T-S [Tualatin S] if you use the right BIOS.
                                  I think it's the next to last version. The last version didn't recognize those CPUs. [Odd.]
                                  Their docs say it supports a 1400-MHz 133-FSB Copper-mine with 512k cache, which of course doesn't exist.
                                  Same trick [older BIOS] might work for you too if a P3T-S falls in your lap and it doesn't work with the latest BIOS.
                                  - Dr Seuss
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Actually the latest BIOS for my mobo does recognize the Tualatin 1400Mhz Celeron properly... Go figure
                                      master hoarder
                                      • May 2008
                                      • 12164
                                      • Bulgaria
                                      Nope, those caps are part of the driving circuit for the transistors on the primary.
                                      When I was recapping mine, I did actually trace the whole 5vsb circuit but was not able to find a critical cap. There are two polyester film caps in that area, though - perhaps one of them might be it (but I'm not sure)? Maybe Everell knows, he's an expert on those 5vsb circuits (and PSUs in general ).
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        The Celeron has 1/2 the cache of the P3-S and so the microcode in the BIOS is different.
                                        If you've got the code for 1.4GHz then you probably have the code for the 512k cache version too, but that's not 100% for certain.
                                        Not meaning to down-talk the CPU you have or anything.
                                        The 1.4GHz P3-S is just one of my pet-favorite CPUs.
                                        - Dr Seuss
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                        • redbaron1007
                                          Yamaha HTR-3065 No power/No Standby
                                          by redbaron1007
                                          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                                          S9 13.7V
                                          Pwr Ry 0V
                                          AC Det 9.1V
                                          Mgnd 0V GND
                                          The two pins on the transformer for the operation...
                                          09-12-2024, 03:04 PM
                                        • mrcliem
                                          CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                          by mrcliem
                                          Hello...
                                          I got my self a dead CM V700 PSU, with nothing on +5vsb
                                          I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                          As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                          The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                          I have read the datasheet and and still can not...
                                          06-29-2023, 08:18 AM
                                          by momaka
                                          03-12-2025, 03:42 PM
