Powermac G5 late 2005 power supply troubleshooting
  • powermacenjoyer
    • Sep 2022
    • 3
    • Czech Republic
    Note to mods: please remove the first thread i posted. It had crappy title. Hopefully this will make some powermac expert look at it more likely
    So i bought PowerMac G5, which worked for around an hour. Then i decided to partially strip it down and re-paste CPU, after which it still worked. However just after i added DDR2 memory into it and connected it to 220v, the mac made a loud pop noise, diagnostic leds on the front side of motherboard shortly blinked and since then, the power mac has no signs of life at all
    PSU is API4fS13. There is no visibly broken component on the PSU. No bloated capacitors, no exploded mosfets, nothing.
    I tested several stuff:
    5V standby line seems to have some sort of voltage spike after i plug psu in (my multimeter on 20V setting displayed overrange for split second) and then settles to around 0.05V or lower.
    Bridge rectifier clearly works. High voltage capacitors are getting charged and after i disconnect the PSU, they keep their high voltage for a very long time (tens of minutes), which probably means, that there is nothing to drain them to. I'd expect, that if the standby line was operating properly, they'd drain a lot faster.
    I tried shorting PS_ON on the PSU to ground. Nothing happened
    I tried applying 5v to standby rail on motherboard. LED lit up informing me, that i should insert CPU so motherboard very likely isn't toast
    I tried manually triggering the relay, that seems to enable the non-standby lines (PSU always clicked two times after i plugged it in, but since the failure, it no longer does that, and PSU always clicked when i turned the mac on). Relay worked as expected. I could see, that the positive output from bridge rectifier goes to the relay. I presume 5v standby line just bypasses the relay.
    I measured internal diodes on multiple MOSFETS and all reported pretty much same values. I also found two IGBTs (20N60C3), that have got G and E pins shorted, which is weird.
    5V and 25V standby lines are next to each other, which complicates stuff quite a lot. It seems like both rails are controlled by one MOSFET and one transformer.
    Should i try posting the pictures of the board and try to annotate my findings? Did anyone ever try fixing this PSU? I found one guy on this site, but he had faulty bridge rectifier and shorted MOSFETs, which i'd have detected already.
    Should i post pictures of the board and try to annotate them with what i had checked?
  • powermacenjoyer
    • Sep 2022
    • 3
    • Czech Republic
    Re: Powermac G5 late 2005 power supply troubleshooting
    I found two IGBTs (20n60c3) that have extremely low resistance between gate and emitter pins. After desoldering one, the igbt is perfectly fine and short remains. Is that normal? Also my transistor tester labels it as N MOSFET and i also found datasheets for 20n60c3 where it's labeled as mosfet and not igbt. If that's true, gate and source are shorted out.
    I found even weirder thing. None of the transformers have any expected resistance of their windings
    When i measure two pins, i either measure dead short between them or infinite resistance. Could the transformer failure cause the loud bang, but at the same time not be hot enough to burn through the yellow tape insulation?
      • 31303
      20n60 is mosfet
      transformers are copper, the windings should have low resistance.
      so, when you removed the mosfet, was the short on the fet or the pads on the board?
      • powermacenjoyer
        • Sep 2022
        • 3
        • Czech Republic
        Originally posted by stj
        20n60 is mosfet
        I could never measure resistance bigger than literally dead short.
        The short was on the pads of the board between G and S pins of the MOSFET. MOSFET itself is fine and measured in my LCR tester as N MOSFET
          • 31303
          look at the gate driver circuit - if your lucky it will just be a shorted diode or ceramic cap
          • tvguy12012012120
            by tvguy12012012120
            02-07-2025, 05:13 PM
          • Adenitz
            Troubleshooting Vestel TV, has standby, but cannot turn ON
            by Adenitz
            I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
            Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
            Both boards are shown in the attached photos.
            What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
            12-27-2023, 03:43 AM
          • jason123
            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
            by jason123
            Hi there,
            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
            I see 2 posts that are relevant:
            https://www.badcaps.net/forum/troubl...j-oled-5-blink
            https://www.badcaps.net/forum/troubl...g-hardware-dev...
            10-29-2025, 02:01 PM
          • toomanydatsuns
            Logic Board / Schematic for Apple Power Mac G5 "Late 2005" (A1117)
            by toomanydatsuns
            Hi all! So happy to have found this community.
            I'm looking for a schematic or a board view of the logic board used by the "Late 2005" Apple Power Mac G5 Quad-core or Dual-core.
            Apple uses identifiers 820-1628, 820-1628-A, and 661-3726 for this part.
            Since the schematics seem very hard to find, I'm specifically interested in Apple's "U4 (Kodiak)" implementation of the IBM CPC945 northbridge, and particularly how Apple wired the memory controller pins.
            There's tons of misinformation about this chip online, and I'd be...
            01-21-2022, 07:07 PM
          • fharris1977
            Vizio D50u-D1 Dead Set No Standby
            by fharris1977
            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
            12-28-2023, 10:25 AM
