High Pitched Whine - Antec Power Supply
  • rokkaholik
    • Jul 2010
    • 21
    I recently aquired an Antec SmartPower 2.0 450W Power Supply. Although the power supply does work, it makes a very high pitched, low volume whine and the outer fan will not work.
    I removed the supposed bad fan and when plugged in to the motherboard, it works fine, just not when it's in the power supply itself.
    Looking closely at the board and caps, I did find a 2200uF 10v cap that was slightly domed, so I removed it and looking closely, it's broken open very slightly on the top as well. I have a new one coming.
    The power supply does still work without it (very brief power on/of just to test) and the whine is still there, so it must be something else.
    What would normally cause this whining? The power supply works fine either way, but I'd like to know just in case something is ready to go.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: High Pitched Whine - Antec Power Supply
    https://www.badcaps.net/forum/showthread.php?t=4986
    if the caps in your PSU are Fuhjyyu, replace them. ALL of them.
    there's a reason why the folks here call them "fuckyou" most of the time..
    • delaware74b
      • Apr 2009
      • 628
      x2 - recap it completely except for the input filter cap. Been there, done that, got the t-shirt
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • c_hegge
        • Sep 2009
        • 5219
        The "bad" fan is not bad at all. it is temperature controlled and only turns on when the PSU gets REALLY hot. When I get failed smartpowers, I never re-cap them. I just gut them and use them for fans and wires, since re-capping rarely fixes the squeal.
        • Toasty
          • Jul 2007
          • 4171
          See also:
          https://www.badcaps.net/forum/showthread.php?t=2224
          and (very similar & related)
          https://www.badcaps.net/forum/showthread.php?t=8403
          BE SURE to replace the 22uF/50v & (2)1000uF/10v caps. If that 22uF blows, say goodbye motherboard.
          Toast
          veritas odium parit
          • Scenic
            o.O
            • Sep 2007
            • 2642
            the primary caps were also blown on my antec (Truepower 550 EPS with Fuhjyyu everywhere ; primaries bulging..)
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • SoporteHR
              LG 42PQ30R TV power supply does not work high voltage. (Liteon PS-7411-1-LF Rev. 2.1
              by SoporteHR
              Greetings to all, I hope you are well.
              I consult you because I have a problem with this power source.
              The TV when it is connected to the electrical power turns on the blue light but does not give an image. the source is heard a hum.
              When I disconnect the power from the TV plates and power it up by itself, the hum goes away.
              I have the STB voltages of 5vdc. The microcontroller is powered with said voltage and the main board LED lights up.
              but not the 12v or 17v ones, nor the 300vdc high voltage voltages, nor the VS or VA....
              06-20-2023, 04:30 AM
