Corsair RM750x help ID blown components
  • m3g4tr0n
    • Aug 2011
    • 88
    Please help ID the Green varistor. I already have the diode part number found on the broken piece (QH08TZ600).
    • Jul 2011
    • 6059
    Re: Corsair RM750x help ID blown components
    What is your incoming voltage to the switching power supply
    • lotas
      • Jan 2016
      • 4711
      • Russia
      It's not a varistor, it's an NTC thermistor.
      • R_J
        • 9583
        It may be a SCK054 ntc. Measure the original's diameter.
        • m3g4tr0n
          • Aug 2011
          • 88
          what is your incoming voltage to the switching power supply
          230v
          • m3g4tr0n
            • Aug 2011
            • 88
            thanks for the correction.
            • m3g4tr0n
              • Aug 2011
              • 88
              checking this review of the RM750x (2021), mine is (2018) they show NTC Thermistor SCK-037, which seems to be the same diameter (15mm) as the one on mine.
              https://www.tomshardware.com/reviews...-supply-review
              • cheeky2
                Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                by cheeky2
                This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                06-15-2025, 05:12 AM
              • zlr8r
                HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                by zlr8r
                Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                To begin with, this laptop was dead-dead.
                Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                • am getting white power led
                • 5-long-flashes on CAPS Lock and NUM lock
                • then, fan full speed
                • CPU heats up some (smaller die PCH, does not)
                • always constant black screen no matter what's tried
                • no USB recognition
                • no HDMI output
                this is as far as I can get with it and not sure where to inspect next ?
                I tried...
                03-27-2024, 03:13 PM
              • iyas132
                Corsair RM 750 blown schottky diode near ES1DF
                by iyas132
                Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                Can anyone help me identify the component...
                12-30-2024, 01:34 AM
              • zunasthegreat
                Dead corsair VS450 with blown TNY chip (cwt)
                by zunasthegreat
                I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
                The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177....
                08-30-2025, 03:11 AM
              • VitalComputing
                Chuwi HeroBox blown components
                by VitalComputing
                I have a Chuwi HerBox that has a number of blown components that I am having difficulty identifying. No schematic available.
                The fault is that the HDMI port does not really function properly, video looks shaky and has lines. The box boots fine on VGA, so I think the problem is isolated to the HDMI.
                The section below is the only section that seems to have damage to three components.
                1. Blue Arrow = I think this was a capacitor (as it is connected to ground) that blew clean off the board.
                2. White Arrow = I think this is...
                05-28-2023, 02:48 AM
