remote control Part ID help please
  • zen
    • 511
    Hi all
    Part required is a charging chip from a small boat remote control .
    Anyone familiar with chip or manufacturer logo ?
  • redwire
    • 3910
    Re: remote control Part ID help please
    Looks like a TC or TP4056 lithium battery charge controller - For that IC pin 3 is GND, so why does this board have some tiny part on pin 3?
    • R_J
      • 9543
      It is a ME4056 by Microne
      Pin 2 is ground, pin3 is Program, the part off pin 3 is a resistor.
      • redwire
        • 3910
        That IC looks much better, matches OP's circuit and logo.
        The "4056" is widely copied in china but strange some have different pinouts. Note these have a thermal pad and need some extra heat to desolder.
        • zen
          • 511
          Cheers guys & spot on RJ , it is a Microne manufactured chip .
          Pin configuration varies from the TP version i initially tested .
          • zen
            • 511
            Trying to repair 2 of these remotes , that have had a higher supply used .
            Charging chips mentioned faulty on both .
            One of them is now destined for the scrapyard in the sky , as main micro controller has an internal S/C .
            Type STM32F030C8T6 , which also has an internal 64K programmable flash .
              • 31036
              try to read the flash with an ST-Link or a 5v serial2usb adapter
              • zen
                • 511
                Cheers , but doubt it would be viable for me to spend more time on the one with micro failed .
                Will focus on the other as he only really needs one to work.
                • zen
                  • 511
                  Time to abort mission .
                  Customer must had supplied such high voltage input , that seems all the chips on board have faulted .
                  Not viable to continue on such a cheap device .
                  • tmhobadcap
                    Pioneer VSX-522-K remote control not working???
                    by tmhobadcap
                    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                    12-24-2020, 01:44 AM
                  • piipo
                    Old Privileg 5.1 speakers remote control question
                    by piipo
                    Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                    09-18-2024, 01:55 AM
                  • hemant_2222
                    Schematic for Denon Remote Control RC1156
                    by hemant_2222
                    Hello Everyone,
                    Hope everyone is enjoying their repairs at hand!.
                    I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                    I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                    Please refer to the attached picture, i think the voltage divider is missing...
                    10-06-2023, 02:05 AM
                  • dfear
                    hitachi 75hl16t64u - not responding to remote control
                    by dfear
                    I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                    It came in for a power issue which I have finally resolved by replacing the power supply.
                    The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                    Anyone have a clue how to fix TV?
                    FYI: I have checked the remote work s by pointing it at my camera on my phone....
                    09-02-2024, 12:15 PM
                  • wolf1976
                    wireless receiver for 6 speeds fan control with remote control
                    by wolf1976
                    hi i have a receiver that is destroyed from the overvoltage i guess
                    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                    the motor fan has not label
                    i have an other receiver operational
                    In your opinion can i measure the voltage at the output ?
                    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                    thanks in advance...
                    07-23-2025, 03:12 PM
